Ramcharger Tank in 1st Gen
Old Oct 4, 2005 | 07:51 AM
Mcmopar's Avatar
The Ramcharger I pulled mine had the two end members "rivited" to the frame, the middle one was "rivited" also but did not support the tank, it just reenforces the frame.
Old Oct 4, 2005 | 09:28 AM
mhuppertz's Avatar
The truck frame doesn't need the additional frame support, and you can make the straps out of scraps. Just remember to use some kind of padding between the straps and the tank, and between the tank and anyplace it touches the truck on the top. Wear holes are bad! I'm going to wait until my brother is not home, then relieve him of his Ramcharger tank...
Old Oct 4, 2005 | 09:32 AM
Mcmopar's Avatar
The stock trucks had no support padding, they just bolted up tight.
Old Oct 4, 2005 | 11:35 AM
andyr354's Avatar
How are you going to go about filling the tank?
Put a filler in the bed floor, hidden in the fenderwell, ect..?
Old Oct 5, 2005 | 12:07 AM
cLAYH's Avatar
I've seen boxes that have the filler mounted in them. You just cut a hole in the fender and mount the box in. Yeah its not as clean as the factory filler but it works.
Old Oct 5, 2005 | 07:33 AM
Mcmopar's Avatar
Put it inside the box on the side to the back of the wheel house.
Old Oct 5, 2005 | 04:29 PM
cLAYH's Avatar
No good, I often carry a 10.5 camper. That's when I need the 2nd tank the most!
SRobertson
Oct 31, 2008 12:35 PM
Begle1
Jul 30, 2006 08:44 AM
cLAYH
May 23, 2006 06:59 PM
Begle1
Apr 13, 2006 12:03 AM
