Ramcharger Tank in 1st Gen
Old Oct 2, 2005 | 10:14 PM
mhuppertz's Avatar
Is it true that a late 80's, early 90's Ramcharger/Trailblazer fuel tank will fit a 1st Gen? I know where one is, and am trying to horse trade for it.
The spare tire area is useless for anything else!
Old Oct 2, 2005 | 10:33 PM
Holsteinman's Avatar
A Ramcharger one will fit. You might run into clearance issues with the exhaust. Do you mean Trailduster? Trailblazer is a GM product, a think Chevy.
Old Oct 2, 2005 | 10:35 PM
mhuppertz's Avatar
Originally Posted by Holsteinman
A Ramcharger one will fit. You might run into clearance issues with the exhaust. Do you mean Trailduster? Trailblazer is a GM product, I think Chevy.
I just washed my mouth out with soap for getting the name wrong! Yes, I meant TrailDuster. Thanks for the info.
Old Oct 2, 2005 | 11:01 PM
SmokinFive9 4x4's Avatar
There's also a tank available from American Designers thats made to fit late-80's F-series pickups. Its flat on top and fits in the same area on those trucks where the spare tire space would be. I imagine you'd be able to make it fit with some creative mounting. Only reason I mention this is because the Ramcharger tanks are like what? 18 gallons? This is 30. Quite a bit deeper but if you don't do trails I doubt it sits low enough to be a problem. No lower than a hitch anyways. Make a heck of a range with the stock tank. 60+ gallons? at even 15mpg that's 900 miles. it's 300 bucks if I remember right but if you look at some of the aftermarket high capacity tanks that's like 1/3rd the cost.
Old Oct 3, 2005 | 10:15 AM
12vchevydually's Avatar
My 84 Ramcharger has a Stock 34 gal Tank.
Old Oct 3, 2005 | 01:42 PM
mhuppertz's Avatar
That's what I was thinking. 34gal is bigger than my stock tank and would be plenty for a tank 2 installation...
Old Oct 3, 2005 | 04:09 PM
Winr's Avatar
The easiest way to install the Ramcharger/Trailduster tank is to remove the last two frame crossmembers from the R/T and install them in your frame then the tank bolts right in. There is enough room for the exhaust ( thats where it is on the R/T)
It sounds harder than it is.
Old Oct 3, 2005 | 04:19 PM
Mcmopar's Avatar
You actually need the last 3 cross members. The one at the back has the holes for the "J" bolts, the center one is support/stiffening of the frame, and the third one is where you connect the straps. The straps, bolts, etc. are still available through Chrysler.
Old Oct 3, 2005 | 05:25 PM
Winr's Avatar
I dont have the center (stiffining) on mine nor recall the Ramecharger frame I removed it from having one. There is however a crossmember spot welded to the floor of the Ramcharger, is that what you are speaking of ? If it is, it's part of the rear floor support and not part of the frame and is not required.
Old Oct 3, 2005 | 05:38 PM
cLAYH's Avatar
I'm stripping a RC next week and am keeping the tank for my truck.
Any tips on fuel line routing and switch mounting? I'm guessing a 4 port swt will be nessecary for the return line?
Old Oct 3, 2005 | 07:08 PM
Winr's Avatar
I think I have an extra switch on the shelf ( NAPA Brand) I'll try to find it and post the part #.
Old Oct 3, 2005 | 09:04 PM
mhuppertz's Avatar
What are the common years, 80-93?
Old Oct 3, 2005 | 10:13 PM
vinny's Avatar
I was thinkin' about this too...
I have the tank but the "charger" is long gone...looks like I'll be fabbing-up some mounts, etc...
How many wires go to the fuel gauge sending unit? What kind of dual position switch would you use on it?
I'm thinkin' running on the Aux tank till it stutters is NOT going to work on our trucks.
Vinny
Old Oct 3, 2005 | 11:33 PM
12valve@heart's Avatar
Vinny
I hate to admit it but it actually does work. Don't recommend it but it does work. I have an auxillary bed-mounted tank and the sending unit doesn't work. I try to watch mileage and switch before I run out but I have run out several times and when the power quits, I just reach down and flip to the other tank. Another 5 seconds of coasting in gear and she roars back to life. Obviously, an auto trans would be a different story.
Old Oct 4, 2005 | 01:52 AM
vinny's Avatar
Yeah, I got an auto...
I'm thinkin', hummm...
Maybe some serious recreational time on the side of the road with a 11/16 wrench...
Vinny
