Quick turbo question
Old Dec 10, 2008 | 01:52 PM
dgbeck's Avatar
Will a hx40 16cm exhaust housing fit on an h1c. Looking to do the 60mm compressor upgrade but would like to go to 4" exhaust.
thanks Doug
Old Dec 10, 2008 | 02:25 PM
peobryant's Avatar
Do you have access to the whole HX-40, or just the housing?
Old Dec 10, 2008 | 02:38 PM
dgbeck's Avatar
just the housing , were you thinking just go with Hx40 instead of upgrading the h1c
Old Dec 10, 2008 | 03:31 PM
peobryant's Avatar
Yeah, you'll be happier in the long run if you upgrade your turbo to newer technology. Most people don't stay stock for long, and thats about all the H1C is good for, even with the 60mm comp. wheel upgrade.
Old Dec 10, 2008 | 03:46 PM
thanks Doug
It will bolt together but it won't work real well.
Old Dec 10, 2008 | 03:56 PM
dgbeck's Avatar
at what point in upgrades / hp range should one consider going with the hx 40 instead of the 60mm compressor upgrade
thanks again
Old Dec 10, 2008 | 03:59 PM
Any injectors bigger than 190's (or stock non-intercooled injectors) should get a bigger turbo like an HX-40 or one of the S300 based turbos.
Old Dec 10, 2008 | 04:18 PM
dgbeck's Avatar
thanks for the info... decisions,decisions,decision,??????,$$$$$$
Old Dec 12, 2008 | 12:03 AM
CaptainChrysler's Avatar
If the housing is cheap and WG'd I would ****** it up.
jcmoyer2004
Sep 28, 2008 05:09 PM
quicksilvr
Jul 21, 2008 10:17 PM
Dan Marino
Apr 20, 2008 03:57 PM
the496rocket
Oct 12, 2007 06:56 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
