Put p-pump in or wait untill new motor is done??
Old May 14, 2010 | 08:04 PM
DNRCustoms's Avatar
Ok, looking for a few unbiased opinions. The plans are to put a p-pumper in the 1st gen I know right.. Well, I think it will be sweet so thats all that counts. Now that we have that out of the way!!
Should I wait untill I rebuild the whole p-pump motor and go that way... Which will have o-ringed head, new piston's/bearings the works, Hamilton cam head studs and a few other goodies
OR
Swap the p-pump onto the first gen with maybe a cam and have some fun?
But the problem is, my trans is not going to handle any more pwr. So, I think I can afford this yr to do the trans and swap the pump with a cam. But, I dont think I can swing a motor build and a trans build. So what would you guys do??
Old May 14, 2010 | 08:08 PM
92smokin blacky's Avatar
I'd say wait til the motor is done, put a manual in it, and then sell that 47rh to me!
Old May 14, 2010 | 08:16 PM
BC847's Avatar
1st Generation Admin
Unless you just like fixing stuff, you've answered your own question . . .
Old May 14, 2010 | 09:31 PM
Preci Cruz's Avatar
p-pump
put my p-pump in and killed my auto trans. Waiting to put in a 47re with upgraded converter/valve body.
Old May 14, 2010 | 10:16 PM
The_Head's Avatar
How do you kill the transmission by putting a P-pump in? Aren't they pretty weak at stock settings just like a VE?
Old May 14, 2010 | 10:55 PM
Respond very quickly with fuel plate, delivery valves, timing, Gov. springs
Easily 450hp worth of fuel right there.
Old May 15, 2010 | 01:47 AM
W150CTDproject's Avatar
id just wait off on everything. build the motor, save, build the trans and put it all in at once. theres nothing wrong with ur VE i take it right? id just hold off until u have both ends built and then put it all together at once. my opinion. cuz with the P pump on the VE motor the injectors would need tended to. 2nd gen sticks changed out with 1st spray pattern nozzles to make it work correctly ( or i do believe anyways, i could be wrong. i just kno pop pressure and spray patterns are different)
Old May 15, 2010 | 09:35 PM
schamran's Avatar
Sold. Currently searching for a '98 12 valve 4-door short bed. JK. lol
irocpractice
Apr 7, 2008 06:01 AM
marv h.
Jan 30, 2008 08:15 PM
DZLROKET
21
Oct 30, 2007 09:40 PM
chucktuna
Jun 5, 2007 09:04 AM
2k1yzfr1
19
Dec 5, 2005 08:27 PM
