Truck starts and dies..untill I went back to stock, now no keyless entry
Old Jun 4, 2007 | 07:49 PM
chucktuna's Avatar
I went to go to work today...started up like normal, and idled for 2 or 3 seconds then died flat. Repeated this 2 more times untill I realized something was wrong
So, plugged my Smarty (currently running level 2) in and had the P 0602 code.....checksum error or whatever that means.
Cleared the code (kept the same Smarty level) tried again to start and got the same start & die results.
So, I reset the software back to stock and now it runs fine....I havent done any updates to my Smarty since I purchased it about 6 months ago or so. I understand theres a fix for the P0602 code, but that it may not be related to my starting issue.
Here's the real strange thing, Now my keyless remotes don't work and the security light in the dash is on while driving.
Just wondering if the brain trust on here has any ideas before I'm at the mercy of the dealer. I've still got a bit of factory warranty left.
Thanks,
chuck
Old Jun 5, 2007 | 07:55 AM
chucktuna's Avatar
Bump!
Nobody's got a clue?
Do you guys think that the P0602 code had anything to do with the "dies at start up" problem.
If ,or when, I take it to the dealer, should I just act dumb? .....an easy act to do in this case
chuck
Old Jun 5, 2007 | 08:29 AM
Totallyrad's Avatar
You need to go to Mads web site and update your software I believe. I read somewhere that Marco wrote a fix for that error.
Old Jun 5, 2007 | 09:04 AM
MikeyB's Avatar
I wouldn't worry about the 602 code. That code should get erased when programmed back to stock.
Sounds like an issue with the security module.
MikeyB
97catintenn
Jan 7, 2010 11:33 PM
joelayan
Feb 19, 2009 08:02 AM
WhozNxtLS1
Oct 29, 2008 09:12 PM
Cumminsdude
May 15, 2004 09:13 PM
