leveling?
Old May 15, 2010 | 01:12 AM
dieselmpg's Avatar
leveling?
have anyone raised the rear of their w250 to level it ? what and how did u do it?? thanks
Old May 15, 2010 | 08:08 AM
sooty's Avatar
leveling leaf spring blocks, add-a-leafs, air bags are what i use, i have a car hauler that will get tire interference with weight, if the hitch is too hi, im already a 9" drop, with a lift on the truck, air bags lift 4", add tons of xtra spring capacity, some systems are automated, mine is manual.
Old May 15, 2010 | 06:08 PM
TIMMY22's Avatar
X2 on the air bags...
*Cheap
*easy fast install
*adjustable
*with 100psi, a cubic yard of sand only drops the rear 1" on mine...
Careful not to exceed the weight rating of your tires, it's easy to get carried away overloading your truck with air bags.
Old May 15, 2010 | 06:26 PM
blackfordd's Avatar
Cheap???
Old May 15, 2010 | 07:43 PM
TIMMY22's Avatar
$250 per set...
That's cheap in my book.
http://www.sdtrucksprings.com/index....oducts_id=5964
Old May 15, 2010 | 09:12 PM
sooty's Avatar
125 ebay/
Old May 15, 2010 | 09:15 PM
schamran's Avatar
make sure you buy new ones. the aluminum end caps get pin holes in em and they leak quick.
Old May 15, 2010 | 09:48 PM
blackfordd's Avatar
Suprisingly cheap. I am a novice at this stuff but the prices I have seen are a lot more than that (throw the Kelderman name around). Thanks for the schooling "Tim and Soot". Do you have experience with the bags Randy??
dodgeboy59td
26
Dec 31, 2002 12:05 AM
UTAH
32
Dec 11, 2002 11:47 AM
Fishin2Deep4U
Dec 10, 2002 07:34 PM
j
17
Nov 10, 2002 07:57 PM
