06 Was very! quiet untill 20K..Now-
Most of the time this is due to carboned up injectors. Go and work the dog out of it pulling a good size load for 30 to 45min. and it will clear up. Get the EGT's up to 1000 deg or greater. That normally fixes mine right up.
Hey mine to but mine is loud all the time not just at idle .heck the only time you can hear your self think is when you are a cruising speed and even then it still makes this tick tick tick it drives me crazy.
It's pretty much the same process as setting the lash on most engines. I think the the settings are .10" intake and .20" exhaust. If you do a search there's quite a bit of info if you do a search. I've never done it myself so I don't the specifics.
My truck now has 16,000 miles on it, and tends to do it sometimes. When I tie it to something heavy and push it pretty hard, it settles back down for a week or so.
I relate it to the late model Cats that I work on. The modern day electronic diesel engine makes more hp and RPM than their earlier counterparts. These engines do it while producing less emmisions. High injection pressures, high flow rates, high injection duration times...etc... When you have the capability of making 300hp. and 25 psi of boost and you run around on 100 hp. at 5 psi of boost all the time, things are going to "carbon up". Engine never really gets to operating temperature. By that, I mean getting the iron up to full operating temperature, coolant, and engine oil.
My wife is just as guilty with my truck. She drives 5 miles from from home to work, never gets past 50 mph, and if you could data log the manifold pressure, I bet she doesn't get over 5 psi of boost.
All this being said, now ya'll know why I just bought her a new Jeep.!!!
I notice mine is louder when it's cold. When it warms up where it should be, it gets more quiet. Also, getting it out in the open and puching it wide open for a little while seems to help.
The cause may also be ULSD fuel. Do you add 2-stroke oil to your fuel? That helps too.
