Parking brake cable length
Old Oct 16, 2020 | 09:15 PM
edwinsmith's Avatar
I've decided to replace the parking brake cables on my truck. They are old and dry and don't release completely so I think replacing them is proper.
RockAuto lists 3 different front cables and I don't know which one I need. They list a 96-1/8", 100" and 123-3/8". Since my truck is a full size dually would I need the longest one or one of the others?
I need to order these to get the job done soon since we are moving to Oklahoma sooner that I thought.
Thanks in advance
Edwin
Old Oct 17, 2020 | 10:24 AM
kensmachine's Avatar
I have replaced the left rear cable 4 times. when I got the truck the left cable and looked newer and was seized up so I got a new pair. With in a year the brakes whet out and the trouble was the left rear the cable was sticking and eat the new drum I installed . called dodge and ordered a new set had to gave them the S/N of the truck to order them got the new cables it was the same length as the ones I got at the napa it was a nicer looking cable than the one I was replacing it lasted longer but did the same thing so #3 cable did the same thing at this point I had a Bendix,dodge & Raybestos on the truck I went to the net and dug around found out all the MFG's only make one set of cables and they fit the 2wd and 4wd trucks. So I looked a round the web and called a round count find a cable for the left side that was I think 5" shorter. I called around to places that made custom cables all told me they don't have the brake drum end and wouldn't modify a new cable a little more digging on the net i found a place in LA that would modify my cable so I put the cable back on and marked it as to where I needed it and sent it off a week later I got the cable back in. In the 5 or so years I haven't cable troubles one thing I have trouble is the vent fitting it gets rusty and plugs up then it builds pressure in the housing and the axle seals leak time to clean the vent hope this helps. Ken
Old Oct 17, 2020 | 04:07 PM
u2slow's Avatar
IIRC, the fwd cable length is linked to the wheelbase. (std cab, clubcab, cab & chassis, etc.)
Old Oct 17, 2020 | 10:50 PM
edwinsmith's Avatar
I assumed as much but which cable should I get? I have a standard cab with the regular long bed. Would it be the middle size one or the shorter one since I don't have a crew or club cab.
Edwin
Old Oct 17, 2020 | 11:52 PM
When you get the cables soak them in a bucket of used engine oil for a couple days before installing them....gets the oil down into cables and the casings and helps them last a bit longer.
Old Oct 18, 2020 | 02:49 PM
edwinsmith's Avatar
I would hope the cables come pre-lubed. I just placed the order from RockAuto but I didn't order the front cable. If it's still to much drag then I'll deal with it when I get the rears done. Also ordered the 3 inch wide shoes and all hardware.
Edwin
BearKiller
Aug 14, 2012 11:30 AM
broncobilly
Nov 10, 2007 07:58 PM
dieselcrazy
Jan 28, 2005 11:14 PM
Garz
May 13, 2003 12:01 AM
