Overfilling the Getrag...
Book probly says about every 48k miles. For some reason I seem to change it about once a year < 10k miles
. That gets expensive.
Anyone ever figure out or decide if the top cover leaking is from the vent or the shifter hole? 5 qts in mine seems to leak pretty bad. I've added only one quart overfill this time - 4.5qts after the clutch job and I'm gonna run a vent hose and axle breather vent up to the engine compartment. But I'm wondering which one if leaks from the most....
. That gets expensive. Anyone ever figure out or decide if the top cover leaking is from the vent or the shifter hole? 5 qts in mine seems to leak pretty bad. I've added only one quart overfill this time - 4.5qts after the clutch job and I'm gonna run a vent hose and axle breather vent up to the engine compartment. But I'm wondering which one if leaks from the most....
Originally Posted by Underpsi
I don't see what the big deal is, I used the top pto bolt with the bottle that lucas additive stuff comes in and its a breeze. Could it be more difficult to get at it with 4X4 guys?
I use to take the shifter out until I realized I didn't need to.
theres two screws that holed the shifter into position, and that can come loose and leak oil(uner the shift boot that covers the tower) and will make it look like it coming out of the vent tube. Make shore you get that boot back on tight(the one with the hose clamp!) I used "mild" lock tight(some day you may wont to thake them out!!)
It's been about 6 weeks or so since I had mine overfilled and I guess I'm lucky in that I haven't seen a drop on the driveway....or anywhere else for that matter. I'll probably run this a few more miles then repeat the process only then I'll have some synthetic pumped in this time around. Honestly, I haven't noticed any difference in the way it shifts, sounds or anything else. It still feels the same...
Chuck
Chuck
No wonder the Getrag has such a bad rep.
holeshot440
Feb 18, 2007 07:29 AM
