OEM transmission cooler
Old Sep 16, 2009 | 05:40 PM
Jungle's Avatar
What do you guys think about the OEM transmission cooler that sits under the turbo? The one that is on mine is disconnected & I am wondering should I replace it with something else?
Old Sep 16, 2009 | 05:56 PM
archer39's Avatar
its more of an heat exchanger. its purpose is to heat up the trans fluid in the colder months. I don't think it cools at all so unless if you live in a really cold climate it is not needed.
Old Sep 16, 2009 | 06:00 PM
Free89W350's Avatar
Just remove it like Zach said ( unless you live in a cold climate ). I have been debating taking mine out, it makes it easier to fit in a bigger down pipe and if you want to put twin turbos on it is in the way.
Old Sep 16, 2009 | 06:11 PM
apwatson50's Avatar
um well if the tranny fluid gets hotter than the engine coolant, would it then not cool the tranny? By my gauge, that happens ALOT!
Old Sep 16, 2009 | 06:24 PM
archer39's Avatar
how much can it really cool though its not like there is a ton of surface area in the thing that will lead to cooling. What is the avg. water temp of our trucks?
Old Sep 16, 2009 | 07:16 PM
Jungle's Avatar
I do live in upstate N.Y. & it does get cold!! Any one got a good source for a good heat exchanger? I would think it would act like the heat exchanger in the bottom of the radiator on the gas motors.
Old Sep 16, 2009 | 09:47 PM
BC847's Avatar
1st Generation Admin
A fluid to fluid heat exchanger will always be more efficient than a fluid to air given the same footprint.
And everyone's right, when the transmission fluid's cold, that heat exchanger provides the heat required to bring the fluid up to a minimum operating temperature (REF: Granny creeping to church, pot of peas on the front seat, and it's 17*F outside). When the trans is really loaded (REF: apwatson50), should the fluid get hotter than the engine coolant, then the heat exchanger acts as a very good cooler.
Exactly. Those would be considered a cute mini version of what we have.
Old Sep 16, 2009 | 09:50 PM
dzl_damon's Avatar
water removes heat more than 4 times better than air. The specific heat of water is 1 and the specific heat of air is .24
There are other factors of course, but like BC said.... liquids are much much better as a thermodynamic fluid.
Old Sep 17, 2009 | 03:33 AM
Jungle's Avatar
THANKS guys!!
Does any one have a good one they want to part with. If you do PM me.
Old Sep 17, 2009 | 10:45 AM
james1's Avatar
Old threads are your friends:
https://www.dieseltruckresource.com/...hlight=3924018
Old Sep 28, 2009 | 09:53 AM
MudbillyRedneck's Avatar
Awsome site..
I hate for my first post to be a dumb question....But I have been told that when these " Heat exchangers " get old and go bad...that they Mix the fluids ??
I have a 12v and am putting it into a ford Crewcab with a 47rh trans ....I was going to eliminate the factory cooler,and just go with an aftermarket- air to air , due to what I was told about the mixing issues ??
Can anyone give me an educated opinion about the reliablity of these factory units ?? Mine seams to be in excelent condition , on the outside
Thanks
Old Sep 28, 2009 | 04:37 PM
They can leak internally but usually what fails is the nipples for the heater hoses rot off or the outer case springs a leak near the weld. I would not take it out out of fear that it will fail internally.
SKATERHAULER
Oct 2, 2013 06:34 AM
Shaun Cockran
May 8, 2012 05:52 PM
APD
Jan 26, 2012 10:35 PM
BAJA MAN
Nov 21, 2006 05:49 PM
