Heat Exchanger
Old May 11, 2008 | 07:56 PM
broncobilly's Avatar
Heat Exchanger
For those of you who have had your factory Mccord heat exchanger take a dump (leak), what did you do? I don't think they are available anymore from Dodge? I saw online; that there are quite a few heat exchangers made for marine engines. Would this be a viable alternative? The exchanger on my 93 is rusted through, and needs replacing.
Old May 11, 2008 | 08:13 PM
R C Cola's Avatar
Rusted
Wow, I thought they were aluminum, guess I better check mine.
Old May 11, 2008 | 09:31 PM
I will have to check the material? The other shell of mine is definitely rusted and leaking! If it's aluminum, then mine could have a stress crack? Is pressure testing under water (with low pressure shop air), the way to check if the coil inside is leaking?
Old May 11, 2008 | 09:38 PM
Richie O's Avatar
366 Spring Chicken
Yes my lobster boat has a tranny cooler hooked to the cooling circuit of the engine. Should be easy to find one but price may make you cry. Anything marine is crazy price. I assume you are talking tranny cooler on side of engine? If not Im lost in space.
Old May 12, 2008 | 12:07 PM
james1's Avatar
The Mopar part number for the transmission heat exchanger was originally 4720 005, which was superceded and changed to part number 4746 216. It doesn't matter; Mopar has discontinued the part and apparently no dealer in the US is still holding one of these units.
However, the Cummins part number is 3924018 and the price is $318.05. Last time I checked Cummins still had about 16 of them in the warehouse.
Good luck.
Old May 12, 2008 | 02:02 PM
Tuckerdee's Avatar
Came across these:
http://www.racerpartswholesale.com/c...eat_Exchangers
Old May 15, 2008 | 12:31 AM
James,
Thanks for the current Cummin's part # on the heat exchanger. $318.00 is not a bad price, considering I was looking at marine diesel exchangers - in the $600 range (I know what you mean Richie)!!!! Truckerdee, thanks for that link! A local truck shop came up with a Hino diesel exchanger, which looks like it will work. Thanks again all for the help!
Old May 19, 2008 | 06:59 PM
James or anyone else,
I went to this web site http://tinyurl.com/4l54eo and punched in the Cummin's part number, 3924018 for the heat exchanger. The site came up with a part listed as clr/oil for $243.80. Is this the correct part (heat exchanger)??? I can't seem to navigate the official Cummin's site, as I do not have my engine serial # on hand.
Old May 19, 2008 | 07:21 PM
sdstriper's Avatar
3924018 is the new Cummins p/n on QuickServe but I could not get any info to show on it, no price either. Even the old number 3914759 doesn't give pricing and shows factory part status at checkout.
Old May 21, 2008 | 10:46 AM
james1's Avatar
You can telephone Cummins Power South here in Atlanta at 404-763-0151. The "factory" currently has eight (8) units in stock and, for individuals without a corporate account, the price is $318.05 plus shipping (as of May 20, 2008).
Cheers,
Old May 21, 2008 | 10:48 PM
Thanks James and SD! Still trying to decide if the 'budget' will allow a new exchanger? I will probably have to go used, as I need to replace my exhaust $$$$
crossy
Jan 24, 2005 07:04 PM
gottahavediesel
Dec 7, 2004 08:05 AM
BBWD
Oct 21, 2004 06:29 PM
apache
Mar 3, 2004 07:11 AM
DieselDaze
Oct 25, 2002 06:50 PM
