Relocating Auto Trans Heat Exchanger
Old Oct 21, 2004 | 07:06 AM
BBWD's Avatar
Are there any tips on doing this when installing twin turbos??? Location, brackets, parts needed, best way to do this, etc. Advise needed. Thanks in advance.
John (DH)
Old Oct 21, 2004 | 04:04 PM
Trucks I've seen with twins just delete it and put a big air-to-oil cooler out front.
Old Oct 21, 2004 | 06:29 PM
AlpineRAM's Avatar
I think the auto trans heat exchanger is a really nice to have thingie- while the engine is cold it will help you warm up the coolant and when hot it will get the atf down to just about right temp.Since these trucks already get into cooling troubles if you use more than double the stock HP for a longer period of time (What a flimsy type of engineering was that )I think that reducing airflow over the cooler might not be the best idea.
AlpineRAM
autocross72
Jan 2, 2009 05:18 PM
DodgeDiesel61
Oct 8, 2008 06:02 PM
BC847
Jul 24, 2008 05:10 AM
Joedodge63
Sep 23, 2007 06:36 PM
Jambbii
Jul 20, 2005 09:48 PM
