NP205 front output yoke
Old Jul 25, 2006 | 08:51 AM
andyr354's Avatar
Mine is in bad shape. Trying to find a new one and so far no luck yet.
Any leads on where to look? Guess I haven't tried chyrsler yet.
Andy
Old Jul 25, 2006 | 10:43 AM
flashgordon's Avatar
Andy
Why do you need to replace it? if the seal surfice is bad you can speedy sleve it!
if it leaking thru the splines, you can buy a rubber washer.(or just put silcone on the spines and retork the nut!)
unless the u-joint has spun on the yok or a broken bolt can't be remove, you can save it .......I did with a speedy sleeve.
Old Jul 25, 2006 | 11:11 AM
Mr. Plaine's Avatar
If it is just the seal surface then a speedy sleeve is the way to go, but if you need a new yoke just go to a driveline shop or any spicer dealer, it is a spicer part, you might have a little trouble looking up the part #, but shouldnt be too bad. I wouldnt go to the dealer.
I use jesse at high angle driveline, he will for sure be able to get you that yoke, and at a good price, check it out highangledriveline.com.
Ian-
Old Jul 25, 2006 | 11:27 AM
andyr354's Avatar
It was allowed to run loose before I got the truck and now does not fit tightly on the splines.
I will give HAD a call and see what Jes has to say, need to get some price ideas for my rock bugy anyways.
Andy
diesel402004
Apr 25, 2014 08:33 AM
Emoo60
Jul 11, 2008 07:07 AM
feveree40
Dec 19, 2007 03:18 PM
97catintenn
Jan 2, 2006 12:18 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
