NP205 Front Output Shaft Bearing Replacement
Old Apr 24, 2014 | 05:12 PM
diesel402004's Avatar
Hey all,
Replacing my TC front output shaft bearing. According to this instruction, I'm going to remove a snap ring after removing yoke and bearing retainer. Do these bearings remove from the outside, or do I have to remove the output shaft assembly and remove the bearing from inside the case? Also, anyone know the part # of the 23 spline front output shaft bearing? As always, thanks in advance!
D
Old Apr 24, 2014 | 05:35 PM
maybe368's Avatar
Here is a rebuild guide...Mark
Old Apr 24, 2014 | 05:38 PM
Philip's Avatar
Use the 23 spline input shaft bearing. The front output is a 6 or 8 roller bearing. The input shaft bearing is a 12 count roller bearing. They do interchange.
In that link someone has installed the higher count roller bearing somewhere during its life.
Old Apr 24, 2014 | 08:40 PM
So, philip and maybe, you missed my question. I had posted the same link maybe and in those instructions it shows removing the snap ring under the bearing retainer for the front output shaft, and I can't tell if the bearing comes out from the outside, or if you have to remove it from the inside. Also, that same bearing in the picture, does anyone know the part# of that bearing?
Old Apr 24, 2014 | 09:09 PM
bgilbert's Avatar
Removes from the outside. Nachi bearing number 6307.
Old Apr 25, 2014 | 08:33 AM
sooty's Avatar
ive never seen a bad lower front go down, even when the case runs dry, pulled dozens of them apart,building doublers, is it physically loose or just leaking?
MARF75
Apr 10, 2012 01:48 PM
DNRCustoms
May 19, 2008 08:52 AM
Ram1999
May 4, 2008 03:49 PM
feveree40
Dec 19, 2007 03:18 PM
andyr354
Jul 25, 2006 11:27 AM
