NP205 Output yoke nut torque spec??????
Old Jan 24, 2003 | 08:28 PM
1stGenBikeHauler's Avatar
For those of you with a service manual I have a question.<br><br>I would like to know what the torque spec is for the nut holding the output yoke for the REAR drive shaft.<br><br> There seems to be some play in the spline. Its not leaking and it really doesn't feel loose in the fore/aft direction but when you turn it there is some movement in the splines. I dunno I was going to take it apart and look at it but I dont know what the torque spec is for the big nut holding the yoke.<br><br>Thanks for any advice!<br><br>MD<br><br><br><br>
Old Jan 24, 2003 | 09:51 PM
Redleg's Avatar
Re:NP205 Output yoke nut torque spec??????
It might be a problem with shims. I had mine tore apart because of play in the fron t shaft, you had to play around to engage/disengage too. I was told it had been worked on before and wasn't shimmed properly. They said everything looked great, corrected the problem, and now it shifts great too, been using 4wd all week.
Old Jan 25, 2003 | 08:17 AM
Grey Wolf's Avatar
Front &amp; Rear yoke nuts are shown at 130 ft lbs for '93
Old Jan 25, 2003 | 12:31 PM
<br><br>Thanks for the reply Grey Wolf. Thats exactly what I was looking for. <br><br>I need to get a manual mysef ...what is the part number on your manual? Does it include info on the Getrag and diesel, or are those seperate books?<br><br><br>Thanks again,<br>MD
Rick 12v CTD
Jan 20, 2010 02:34 PM
CanuckCTD
Jul 9, 2007 05:58 AM
Mopar Kid
Mar 29, 2007 07:22 AM
andyr354
Jul 25, 2006 11:27 AM
97catintenn
Jan 2, 2006 12:18 PM
