Next lift pump...
Old Aug 9, 2007 | 10:44 PM
rbrettctd's Avatar
Next lift pump...
What should I do? Piston lift pump or electric? Or are yall using the electric to get it to the lift pump? Im gonna need plenty of fuel eventually, as hopefully next summer Ill be throwing in some edm's and either a big single or some home brewed twins.
Old Aug 10, 2007 | 08:46 PM
I'd skip the piston pump. I'm very happy with my parallel Walbro setup.
Old Aug 11, 2007 | 10:26 AM
rbrettctd's Avatar
Do you have a writeup on that Dave, or is it just pretty simple? I didnt see anything electric wise in the sticky.
Old Aug 11, 2007 | 10:29 AM
It's not BC847 or Jim Lane quality: https://www.dieseltruckresource.com/...d.php?t=120066
Old Aug 11, 2007 | 12:46 PM
rbrettctd's Avatar
Looks good to me. I didnt see anywhere, are you still running the 391? And if Im still running stock lift pump, does it matter if I go with the 391 or 392?
Old Aug 11, 2007 | 03:28 PM
ofcmarc's Avatar
Whatever happened to the 2nd gen lift puimp with a bypass regulator after the filter that bonzitoyota was working on?
I've been short on $$ or I probly have done that one myself.
Old Aug 11, 2007 | 06:45 PM
banzaitoyota's Avatar
I have installed it and run it. Works great. Need to post pics
John
Old Aug 11, 2007 | 08:33 PM
I still have the 391. I am concerned about excessive inlet pressure to the plastic fuel heater when trying to push more flow through the filter. Pressure drop across a clean FS1221 (longer than stock) is 7 psi.
Old Aug 11, 2007 | 08:42 PM
rbrettctd's Avatar
So youre saying the 392 maynot be a wise choice?
Old Aug 11, 2007 | 08:47 PM
It would make me nervous to hit that fuel heater with more than the 25-30 psi it's seeing now. It's only 15 year old plastic.
If you wanted to get rid of the fuel heater (need a different spud, I think Bill has the part # handy) the 392 wouldn't scare me. With the truck being my DD and the winter temps getting in the waxing range pretty regularly, I need to keep the fuel heater.
Old Aug 11, 2007 | 08:50 PM
rbrettctd's Avatar
We dont see too cold of temps here, but Id still hate to get rid of it. Besides, Im sure the 391 would be enough for me now. Once I get into (if) the edms and compounds or big single, I could add the piston pump and that would supply it fine right?
Old Aug 11, 2007 | 08:59 PM
Nope, the piston pump just loafs along when the Walbro runs.
I can't pull the 391 below 15 psi with the pump turned up to the edge of runaway and plenty of fuel to break 400 HP if I had the air. I'd say it's adequate.
Old Aug 11, 2007 | 09:05 PM
rbrettctd's Avatar
Good deal. I think Ill get a test gauge and check mine out. I imagine once I get intercooled and go another turn or 2 Ill be needing something.
Txwelder
Nov 26, 2025 01:53 AM
tfdcruiser
Mar 24, 2007 05:56 PM
BIGJRAM
Feb 27, 2006 04:57 PM
Txwelder
May 19, 2005 06:10 PM
jonmurr
Jan 24, 2005 01:27 PM
