Need some turbo thoughts and advice....
I've been thinking of picking up a rebuilt HX35 here locally, but the only thing that is holding me back is the fact it is not equipped with a waste gate. I'm pretty picky about these kinds of things.
I would not be using this turbo until I had a IC set-up installed, so wondering what boost numbers you HX35 users are seeing...especially those with no waste gate. I'm thinking, from what I've read and come across, I'd likely see mid to high 20's? But then it would also depend on what's been tweaked on my pump I suppose as well?
According to your sig, the pump is stock other than a timing bump, right?
Well, I only have 2 turns on my fuel screw with slightly larger injectors (4x.014s) and, granted I have a Super 40 compressor with a 60mm wheel, I've seen a max of 37psi with the wastegate plugged/disabled. A stock hx-35 is a 56mm or 58mm (?) wheel. That being said, I think you'd be well under 40psi with your mods and no wastegate.
Being that your pump is stock, just run the stock turbo for now while you save up some coin for a good turbo that will give you some room to grow in the future should you decide you want more get-up out of it.
bsj04
09-20-2007 08:09 AM
ryan466
08-30-2006 10:10 AM
PapaPerk
23
01-01-2005 07:33 AM
