Need lift pump upgrade!
Old Jun 18, 2009 | 02:39 PM
  #31
Thunderhog's Avatar
Originally Posted by Ace
You really should consider upgrading the plumbing before you even start thinking about pumps. You'd be surprised what the stock diaphragm pump will do running through a bigger pickup, aftermarket filter head w/bigger filter and 3/8" supply line all the way through.
Amen, Brother! Mine runs 9 psi at idle and drops to MAYBE 7.5 or 8 at WOT.
Stock lift pump, bigger lines.
Old Jun 18, 2009 | 02:46 PM
  #32
speed75's Avatar
so just adding bigger line from tank to stock lift pump gets you more psi how good do the stock filter heads flow with bigger lines before and after
Old Jun 18, 2009 | 04:55 PM
  #33
Originally Posted by CE_TX
Is the Airdog fuel systems a good upgrade if you plan on bombing the truck to run 300+ RWHP??
Out of the "fuel system in a box" setups, I like the Airdog the best.
Old Jun 18, 2009 | 08:58 PM
  #34
CE_TX's Avatar
I keep reading good things about the Airdog and after reading the installation instructions, I'm pretty sure this is the route I will go. I like overkill.
Old Jun 18, 2009 | 09:29 PM
  #35
Tater93's Avatar
I'm into overkill too, thats why there is an AirDog going on mine in the near future. Then no matter what I do, I know I have enough fuel supply for it.
Old Jun 18, 2009 | 09:47 PM
  #36
Ace's Avatar
Ace
It doesn't matter how big a pump you put on it if it can't suck enough fuel through the pickup.
Old Jun 18, 2009 | 11:20 PM
  #37
BurrisWill's Avatar
Ok guys, I just bought a second gen piston lift pump and want to know which regulator is the best buy for the money?
Old Jun 19, 2009 | 05:22 AM
  #38
Tater93's Avatar
Along with overkill I also don't do anything half***ed! I think the guys that have seen my truck can vouch for that. I would'nt think of putting any electric pump on the truck without 1/2" line from the tank to the pump. I didn't know the supply line size was even an issue till about three weeks ago when my truck left me sitting in traffic becuase it couldn't draw enough fuel.
Old Jun 19, 2009 | 06:21 AM
  #39
Vulcan.
Tater- Usually the Airdog pumps have their own dealio where you drill a hole in the bottom or top of the tank and thread a nipple coming out of the tank and put the hose in there directly to the pump, so it gets all the fuel you want, i think its called a "draw straw"
Old Jun 19, 2009 | 08:01 AM
  #40
CE_TX's Avatar
Yep, with the Airdog you have 20 feet of 1/2" fuel line that comes with the kit.
Txwelder
Nov 26, 2025 01:53 AM
PowrStorkthsRam
Apr 16, 2007 09:10 AM
schu
15
Oct 12, 2006 08:12 AM
Txwelder
May 19, 2005 06:10 PM
