Need lift pump upgrade!
Old Jun 15, 2009 | 09:47 AM
1stgenjake's Avatar
i took my friends for a ride a few mins ago and we did a pull from about 35 to around 80 then when i let out of it it died. so pretty much it ran out of fuel. once i cranked it WOT to prime the pump it fired right back up and ran fine so before I burn up my VE i need to get a better lift pump. so my question is what to get and how much will it cost? i want to get it done soon so i can go play
Old Jun 15, 2009 | 10:00 AM
peobryant's Avatar
Either a low pressure piston pump, or 2nd gen piston pump with a regulator would serve you well.
Old Jun 15, 2009 | 01:16 PM
Erik@LCD's Avatar
I would recommend a Raptor or an ADII so that you have the adjustable regulator.
Old Jun 15, 2009 | 04:43 PM
Big surprise there. Those are nice systems but overly complicated for your needs.
Old Jun 15, 2009 | 04:59 PM
apwatson50's Avatar
Big surprise there.
funny
With stock injectors and turned pump a low pressure pump has maintained 10psi no problem, even with slightly larger injectors i'm sure it'll still keep up. Plus it'll last a long time and if you're alternator goes bad you could keep driving until you run out of fuel. Do that with a raptor/fass and no alternator.
Old Jun 15, 2009 | 08:36 PM
sixb's Avatar
Curious as to what the stock 1st gen lift pump puts out psi wise with say a stock to mild tune.
Is the piston pump a stock 2nd gen 12v item?
Old Jun 15, 2009 | 09:03 PM
0 psi after pump tweaks.
80% of the time.
they run like 4-6 psi stock i believe, if its a good one
gotta get rid of the stockers after some fuel is added.
Old Jun 15, 2009 | 10:04 PM
1985cucv's Avatar
get the piston pump mine goes to about 9 psi wot and 14 at idle with the maxed fuel. costs about 200 buck great buy
Old Jun 15, 2009 | 11:07 PM
1stgenjake's Avatar
80% of the time.
so i need a stock second gen piston pump?
Old Jun 16, 2009 | 07:50 AM
CE_TX's Avatar
Where did you buy yours at? Got a p/n?
Old Jun 16, 2009 | 08:06 AM
peobryant's Avatar
A stock 2nd gen piston pump, without a regulator will push the front seal out of the VE. With a regulator, you can safely run it.
You need the low pressure one found on agricultural equipment, and I believe you can order it from John Deere.
Old Jun 16, 2009 | 12:52 PM
sixb's Avatar
I know the FIRST gen needs a low pressure piston pump old part# 3936320 new # 4988751 @ $186.61 and 2 gaskets old # 3931348 new # 3939258 @ 2.10 each and last a spacer # 3914284 @ 12.86
What i would like to know is did a second gen 12v come stock with a piston pump or did they have a similar lift pump as the 1st gen, Just out of curiosity.
Last edited by sixb; Jun 16, 2009 at 08:31 PM. Reason: Wrote second when I wanted first
Old Jun 16, 2009 | 12:55 PM
apwatson50's Avatar
The come factory with a piston pump that puts out ~40-50psi
Old Jun 16, 2009 | 02:20 PM
peobryant's Avatar
i know the second gen needs a low pressure piston pump old part# 3936320 new # 4988751 @ $186.61 and 2 gaskets old # 3931348 new # 3939258 @ 2.10 each and last a spacer # 3914284 @ 12.86
I'm sorry, I didn't understand your question.
Like apwatson said, the 2nd gens came stock with a piston pump, unlike a 1st gen diaphram lift pump.
Old Jun 16, 2009 | 02:54 PM
sixb's Avatar
No problem, I have a hard time putting my thoughts into words
On my conversion I am using a 92 ctd with a 94 fuel filter head and will run the piston pump. I wonder if I could take the fuel line from any 2nd gen 12v from the piston pump to the fuel filter head. I still need to make one up to go from the filter to the I/C and it may be easier to just make both.
