metal flakes in oil
metal flakes in oil
When I chaged my oil I noticed some small metal flakes in the oil.I put a mechanical oil pressure gauge on. Cold pressures idle 25psi ,full thottle 55psi.Hot pressure idle 15psi ,full throttle 30 psi. I don't have any knocking sounds from engine. Is it time for rod and main bearings? What is procedure for changing rod and main bearings?
Is it like brass or copper looking?
Assuming high miles it shouldn't have any slag or shavings in it from manufacturing.
Oh and definately immediately pull the filter and use some tin snips to cleanly cut it open.
I edited my post above to include cut open the filter... But at any length I'd stop driving it and figure what it is.
We just pulled apart the motor on my friend's civic that had a bearing slowly come apart. Those flakes of metal literally ate the whole inside of the engine like sandpaper on steriods.
gpshemi
10-31-2012 09:55 PM
mattmanj2001
08-19-2010 08:18 PM
FiverBob
41
12-16-2003 06:14 PM
