Metal flakes in fuel canister
Old Oct 22, 2012 | 07:46 AM
gpshemi's Avatar
Got a dash light last weekend. Checked for codes with my Bully Dog and it said no codes. Pushed clear and it went away. Towed my toyhauler home with no issues. Last night I went to install a new fuel filter and I see metal flakes in the canister. I wiped them out and they are certainly metal. Truck acts fine, but...probably a lift pump coming apart right?
Old Oct 22, 2012 | 08:35 PM
roughstock's Avatar
no, not necessarily, ive seen the fuel nozzle scrape things up when you are fueling. My old 12V had a metal shroud on the fuel sender that was wearing on some screws in tank and and that is where shavings were coming from. Just my experience.
I wouldnt worry,
Old Oct 23, 2012 | 08:55 AM
gpshemi's Avatar
I could see that in some cases, but this was way more metal flake than that. I would see significant wear in the nozzle opening or the nozzles themselves if that were the case.
Old Oct 23, 2012 | 08:29 PM
gorms's Avatar
I wouldn't say not to worry yet, BUT I have found some hairy looking metal filings in my tank/filters from the pumps. Largest flakes that made it to my pre-filter screen were about 1/4" long, most of the brass ones stayed in the tank for some reason. Good luck.
Old Oct 24, 2012 | 07:54 AM
gpshemi's Avatar
If it was just a flake or two, I'd think differently, but this was a shiney bottom of my drain pal, and I wiped out the majority on a shop towel. I change the filter every 10k. So this has just shown up in the last 10k for sure. I'd have noticed this before. Truck has 70,000 towing miles on it.
Old Oct 24, 2012 | 09:50 AM
johnh's Avatar
there is nothing downstream of the filter other than the lift pump that would generate metal particles , i would replace it to be safe. on the other hand it could have came from the place where you filled up.
Old Oct 24, 2012 | 10:15 AM
gpshemi's Avatar
I thought of that too. I guess my thoughts are
A) It would really suck to get a 41' / 18,000lb toyhauler three states away and the truck quit.
B) At 70,000 miles, how much life can I really expect from it since they're known to crap out?
Might as well bite the bullet and know I'm good. Suggestions on which verion? AD / Fass? Seems to be varies opinions and I want the quietest version.
Old Oct 31, 2012 | 02:41 PM
gpshemi's Avatar
I'll take that as a no...
Old Oct 31, 2012 | 09:55 PM
rockcrawler304's Avatar
Either one would be fine. I think now they are both using a quieter pump. I don't know for sure but from what I have read here I think that is the case.
mattmanj2001
Aug 19, 2010 08:18 PM
arroyojim
Oct 26, 2009 09:57 AM
mikeyy
Jul 22, 2007 03:12 PM
yrusoslow2
Feb 2, 2004 01:11 PM
Dave65
13
Mar 22, 2003 05:41 PM
