metal flakes in fuel filter
Old Feb 1, 2004 | 04:56 PM
yrusoslow2's Avatar
Drained my fuel filter today and found some metal flakes in it. They were shiny flakes and there were quite a few of them. Does anyone have an idea of where they might have come from. I am hoping that nothing major is wrong. Thanks for any help.
Justin
Old Feb 1, 2004 | 05:25 PM
infidel's Avatar
More than likely it's contamination you picked up at the fuel station.
Old Feb 1, 2004 | 06:47 PM
Worst thing it could be is the lift pump eating itself. I think the filter will stop any bits that are big enough to hurt the injection pump. You might want to replace the lift pump as insurance, they're around $120 I think. Out of curiosity, what brand of fuel additive do you use, if any?
Old Feb 1, 2004 | 09:32 PM
kandgo's Avatar
No lift pump on your year as yours is mechanical, I side with contamination,and would check the new filter in a couple of hundred miles, Goodluck,, Rick
Old Feb 1, 2004 | 10:09 PM
infidel's Avatar
Easy way to see if it's coming from a disintegrating lift pump or from the fuel station is to service the prefilter as it is ahead of the lift pump. You should do it anyway.
Instructions- http://dodgeram.org/tech/dsl/filter/pre-filt_clean.htm
Old Feb 1, 2004 | 10:54 PM
Haulin_in_Dixie's Avatar
If they are alumimum they are coming from the tank slide. I am sure it does not do the pump any good, I used to get it until I locked the slide down. There are three screws with a shoulder that allow the pickup and gage to slide up and down, the screws wear into the slide causing the chips which I assume are picked up when running the fuel low.
Old Feb 2, 2004 | 11:17 AM
yrusoslow2's Avatar
I was thinking that it may be that fuel tank slide. I locked it down when I first got the truck but it may have come loose again. I guess the worst thing that could be going bad is the lift pump so that is not so bad.
Thanks again,
Justin
Old Feb 2, 2004 | 11:39 AM
Palmetto_kid's Avatar
Justin, what does the pre-heater screen look like? I agree with Infidel, if its coming from the tank, you should see something in that screen. Its a pretty fine screen too. Dont seem like any big chips should get through it.
Old Feb 2, 2004 | 12:52 PM
Screen did not stop the chips on mine, putting washers under the screws did.
Old Feb 2, 2004 | 01:02 PM
Haulin, it took you two weeks to pick up on that one......im disappointed! lol.......good one though. Back to the drawing board now. shucks
Old Feb 2, 2004 | 01:11 PM
You're quick, it was not on there two minutes and I edited it out.
gpshemi
Oct 31, 2012 09:55 PM
mattmanj2001
Aug 19, 2010 08:18 PM
arroyojim
Oct 26, 2009 09:57 AM
mikeyy
Jul 22, 2007 03:12 PM
FiverBob
41
Dec 16, 2003 06:14 PM
