injector pump
Old Oct 26, 2006 | 08:39 PM
Beamwalker's Avatar
injector pump
pump is somehow leaking out of the bottom. cant really trace it but any help would be nice. am i going to have to rebuild it and can i run it for a while until i get money to do so, without it not feeding one of the injectors and burning that hole up
Old Oct 27, 2006 | 09:28 AM
tboling's Avatar
Exclamation Oring engine side
Check the engine side of the pump,there is a small cap with two torqu's screws holding it on. The oring inside the cap is most likely cracked or broken,the cap is on the other side of the pump across form the timing advance senser. U will have to remove the injection pump to fix the oring. It will apear to be leaking from the bottom. Good luck
Old Oct 27, 2006 | 10:12 AM
efbeason's Avatar
I just had to rebuild my injector pump because of the same problem. The technician told me that it was that the low sulphur fuel had allowed the seals in my pump to shrink and allow them to leak. I had my pump rebuilt and the valves adjusted. It made a difference in the way my truck runs at high RPM.
Old Oct 27, 2006 | 01:50 PM
46johnny's Avatar
I am having the same problem in a "93 model. If I remove the pump is it necessary to mark it in any way to be sure it is replaced exactly the same. I have never owned a diesel before this one so I am green at this.
Old Oct 27, 2006 | 06:04 PM
If it's stock there is a match mark (near the nut that you can reach ).
The shaft is keyed so no worries there.
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
