Injection pump timing/foreign order
Old Mar 6, 2020 | 05:08 PM
Dan s's Avatar
Injection pump timing/firing order
I know I saw this some where on here but can’t find it. I’m sure I put the injection lines on in the right order but I want to check it to make sure
firing order
Old Mar 7, 2020 | 12:53 AM
nonrev's Avatar
Super Moderator
10 Year Member
If it is your ve pump truck it would be like this, 1-5-3-6-2-4
Old Mar 7, 2020 | 09:23 AM
Dan s's Avatar
Checked it this morning. All good. Thanks. Still no start. I don’t get it
Old Mar 7, 2020 | 09:39 AM
Did the throttle arm get re positioned / re indexed on the splined shaft?
Old Mar 7, 2020 | 01:10 PM
Dan s's Avatar
It’s a rebuild I bought. It could be. I’ve tried holding the throttle open while turning it over. Still not even trying to hit. If I put gas on a rag and hold it on the intake it will hit. For some reason i can’t seem to get the air out of the system.
Old Mar 7, 2020 | 01:21 PM
Did the wire to the FSS get bumped off, or not reconnected?
That would cause the same symptoms.
Old Mar 7, 2020 | 01:50 PM
Dan s's Avatar
I’ll check. But that would keep fuel from getting to the injectors right? When I Turn it over it shoots fluid out when I have the injectors lines broke loose to bleed them
Old Mar 7, 2020 | 01:51 PM
Dan s's Avatar
AND WE HAVE A WINNER. I jump the gas to the battery. And bingo. Thanks guys.
Old Mar 7, 2020 | 02:00 PM
Dan s's Avatar
So which one goes to the ksb. I had the hot from the switch hook to it. There were two hooked to the fss.
Fordzilla's Avatar
Could you explain that one, Dan?......Ben
Old Mar 7, 2020 | 02:03 PM
The longer wire runs down to the KSB and the wire that is shorter runs the shorter distance to the FSS.
Old Mar 7, 2020 | 03:54 PM
Dan s's Avatar
well..... no? I meant fss to battery. It’s been a rough couple of days. I feel kinda stupid. I know better. But it’s running like a top. Gonna post some pics on other thread
Old Mar 7, 2020 | 07:52 PM
Fordzilla's Avatar
Got it...My feeble brain should have picked up on that...Thanks Dan......Ben
peobryant
Feb 17, 2009 06:40 PM
sallyman1
Mar 2, 2008 08:36 PM
eastmentCTD600
14
Mar 11, 2005 10:00 PM
shortfieldbreak
Nov 28, 2002 08:45 AM
Lary Ellis (Top)
14
Nov 15, 2002 11:00 AM
