idles fine but thats about it
Old Jul 15, 2010 | 08:59 PM
fatt's Avatar
After I replaced my headgasket and got my pickup running last Friday, I drove 50-75 miles with no problems. Driving to a bonfire I'm cruising along at 50 and suddenly the engine kind of stuttered, like it almost died for a second so my first thought is I'm finally getting the 1/4 tank issue. Nope, still had half tank. So I keep going and start climbing a hill and lose power completely, and the engine kept doing the same deal as before; almost as though it had air in the lines. So I parked it and rode with my buddy the rest of the way. About six hours later we get back to it and it drove perfectly fine for a mile or so until it started again. Got it towed home and I've tried everything I can think; new fuel filter, no fuel leaks, air filter is fine, pushrods are all in place. It will start fine and idle but any pressing on the skinny pedal and it starts to bog down giving a small puff of black smoke and a second later a cloud of white smoke. Except occasionally with the airdog OFF it will rev fine. The only changes from before are Orings, 60 pound valve springs, and I advanced the timing from 3/16 to 1/4. Anyone have an idea whats wrong??
Old Jul 15, 2010 | 09:12 PM
JustRamIt91's Avatar
could some dirt have gotten into the fuel lines? Maybe there is still compression loss?
Old Jul 15, 2010 | 09:22 PM
You are not getting enough fuel for some reason.
Old Jul 15, 2010 | 09:27 PM
RuralCruiser007's Avatar
Have you taken the time to replace the connections of the shut down solenoid? I haven't done mine and whenever there is high humidity conditions I have the same problem. grrrrr
I have to get mine done.
Old Jul 15, 2010 | 09:51 PM
fatt's Avatar
I disconnected the fuel hose from the VE and the fuel comes out in a solid stream. About a half gallon in 10-15 seconds. I took the injector lines loose at the injectors and its getting fuel to all of them.
Old Jul 15, 2010 | 09:53 PM
fatt's Avatar
Havent done that one. Never even heard of it. Is there a writeup anywhere about it?
Old Jul 15, 2010 | 10:01 PM
Onemoparnut's Avatar
Mine did the same thing to me and it was the connection to the fss. Everytime I would get on it the wire would lose contact and the truck would stumble or shutoff.
Old Jul 15, 2010 | 10:06 PM
fatt's Avatar
What did you do for a fix?
Old Jul 15, 2010 | 10:13 PM
dodgenstein's Avatar
Cut the connectors off both wires on the fuel shutoff. Crimp on ring terminals. Remove the nut on top of the fuel shutoff, remove the old terminals, put the ring terminals over the fuel shutoff stud replace nut. This should eliminate the possibility of a bad connection between the spade terminals and the solenoid.
Old Jul 15, 2010 | 10:25 PM
fatt's Avatar
I'll try that tomorrow after work. It's way too late right now.
Old Jul 17, 2010 | 12:41 PM
fatt's Avatar
Dirt in the fuel lines is possible. They sat in the bed for almost a week uncovered.
Old Jul 17, 2010 | 04:45 PM
fatt's Avatar
Not sure if my description was very good so i made a video. http://www.youtube.com/watch?v=AmLZuJgOHPk
Old Jul 17, 2010 | 05:10 PM
G1625S's Avatar
Definitely a fuel supply issue....by the VE I think That's how my truck sounded when I lost the original pump...
Old Jul 17, 2010 | 08:11 PM
soggy's Avatar
Hast thou pulled the injectors to see if they mayhaps have a tip cracked Brother Fatty?
Old Jul 17, 2010 | 10:57 PM
fatt's Avatar
Shore did Soggy. They all look fine to me.
