How much boost and egts
Old Oct 15, 2009 | 05:15 PM
WY FARMER's Avatar
I have a stock 92 auto one turn on the fuel screw. Empty I see about 10 psi and with empty stock trailer it will get up to 15 and my egts will be 1200 or thier abouts. My probe is mounted pre turbo. Dose this seem like every thing is normal would like to get some more power what next? Thanks for the help.
Old Oct 15, 2009 | 05:26 PM
Sounds like you may have a boost leak, but '92's tend to be a little weak from the factory.
'92's have the awful 21 cm turbine housing, you will find that a 16 cm turbine housing will lower your EGT and give you better bottom end response.
Old Oct 15, 2009 | 05:30 PM
feets's Avatar
My 92 is stock with one turn on the fuel screw and muffler deleted. It lbew the boost line off the gauge at 25 psi on the dyno. I think it's topping out around 27 psi.
Old Oct 15, 2009 | 05:35 PM
JQmile's Avatar
Sounds like your laggy housing on the turbo is causing you to have less boost while towing than you should have...see my sig for a few other basic mods you can do to make power The only think that I am missing that most people do is a timing bump.
PS--Wasn't your Plymouth in a car mag a long time ago?
Old Oct 15, 2009 | 06:04 PM
feets's Avatar
The hot rod was in Mopar Muscle Magazine in January 2001, Popular HotRodding in October 2008, and as a background car for a segment of the TV show rides in 2004.
With A Home-Built 800hp Twin-Turbo 440, This 1965 Plymouth Belvedere Is One Of The Roughest Cars To Ever Land In A Magazine And Is Also One Of The Coolest - Popular Hot Rodding Magazine
http://www.popularhotrodding.com/fea...ere/index.html
This old beater has been around.
I really don't care about it not being perfect, as long as it's fun.
Old Oct 15, 2009 | 06:10 PM
feets's Avatar
Yeah, the car is rough and all but did the have to begin the article with the line "Think of it as the Joan Rivers of hot rods"? That almost hurt my poor widdle feeling. Good thing I left it (the feeling) at home that day.
Old Oct 15, 2009 | 07:34 PM
KRB's Avatar
KRB
Sounds like you know turbos...
I can see 24 lbs easy under a load with my mods.
Old Oct 15, 2009 | 09:38 PM
dieselnut416's Avatar
is see 83psi cough cough
Old Oct 15, 2009 | 10:23 PM
92smokin blacky's Avatar
Yeah i bet its your laggy 21cm turbo. I have a 92, and when i had the stock turbo, and it was stock with a straight pipe, it hit about 16 lbs and then when i turned my pump up, it hit about 21 lbs and ran really hot... so I think its your turbo, Then i put an he351 on with the 9cm housing on it and its a night and day difference, I went from 21 lbs to 40 lbs... and it runs way way cooler! and it spools so much quicker. So i say change the turbo or at least the housing
Old Oct 15, 2009 | 10:34 PM
1985cucv's Avatar
yeah the housing also that car is sickkkkkkkkkkk
97DodgeRam
Jul 28, 2010 10:05 PM
SpeedyWS6
Mar 11, 2010 10:19 PM
hemirunner426
Feb 25, 2010 12:39 PM
archer39
Sep 14, 2009 05:25 PM
jrs_dodge_diesel
Jan 26, 2007 08:33 AM
