high idle wont turn off
Old Jul 21, 2008 | 09:34 PM
92cummisw350le's Avatar
why does my truck idle so high, the idle screw is all the way out and the linkage is returning all the way, al so now it wont turn off when you turn the key it idles down but wont shut off gutta pull the lever the fuel selenoid bad
Old Jul 21, 2008 | 10:32 PM
Yes the shutoff solenoid is bad. 99% chance. that exactly what ours was doin when it died. it would shut off fule to like one cylinder but the engine would still run and it idled down and loped and stuff. hope this helps. Brandon
Old Jul 22, 2008 | 12:01 PM
ofcmarc's Avatar
Have you played with the fuel screw? When you crank that screw in, it raises the idle. You should be able to back off the idle but perhaps you are nearing a runaway and can't quite get there (idle). Try shutting it down with the shut down lever. If it won't, You'll have to back out the fuel screw a little bit. Just enough to be able to shut it down.
Old Jul 22, 2008 | 04:16 PM
flashgordon's Avatar
IF you haven't modded your truck or turn up the fuel, i don't thing the rubber on the plunger is bad, but the metal part of the plunger is scared from years of us.
I pull mine out and sanded the rough parts off from the stem of the shut down plunger.............Only cause it to shut done for a week or so.
Added some stanadyne(sorry for the spelling) fuel treatment((purple bottle) it shuts down 90% of the time now and when it don't, i can turn the key back on and then off and it will stop.
To me, this just shows how Crappy of a lube our new low sulfur fuel is
Give it a try before you remove the fuel shut of valve...........It will only cost ya a bottle (1/3 of a bottle) for finding out.
Flash.
Old Jul 22, 2008 | 09:22 PM
yea no the truck has been turned up for a while and it always shut dont no prob i think at 250k the fuel shut off it tired so the cable route is how i fixed that prob. as for the idle i think its to much timing i turned the timeing down a lil bit today but the truck didnt seem to run right and got hot fast so i gues its some thing i will have to live with
kicker210
Dec 2, 2009 08:23 AM
stealman1
Nov 9, 2007 11:07 AM
jmccart
Jun 12, 2007 02:12 PM
qcstunter
Jan 9, 2007 04:10 PM
dieselnewbie
Jan 18, 2005 10:48 PM
