High idle
Could be your lock nut on the idle stop has worked loose?
Maybe your throttle assembly pivot is starting to seize up and is not allowing the throttle to return to the low idle position?
Perhaps the throttle return spring is worn and too weak, or missing?
The assembly pivot is working and the spring is bringing it back. With the truck running I pushed the throttle back and it's idling high. Where is this lock nut you speak of? Truck ran fine, just started today. I pulled over for a bit, got about 40 miles to go before I make it home. I'm seriously tooless (mistake mistake!)
Heya,
If it's loose, you should be able to turn it with a screwdriver or even your fingers. The problem is getting fingers in there.
I'd also check the full fuel screw on the back of the pump.
If it appears to be locked down, I would not drive it. I would have it towed. I would suspect the throttle linkage is coming apart inside and may jam at full throttle.
I carry Good Sam Roadside Assist, so such a scenario isn't a big expense to me. Main reason I carry it is so I don't have to try to hand handle 400 ft/lb lug nuts and heavy rubber under dangerous conditions. Came in pretty handy when DW sheared the flex plate.
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
