Fuel Pin Questions
Old Sep 10, 2008 | 10:48 PM
EatMySmoke's Avatar
Fuel Pin Questions
What kind of changes in performance will I see from rotating my fuel pin? I turned it 90 degrees clockwise so that the deeper side should be facing the radiator/front of the truck. Also, when I took it out, it had some residue on it. Is this normal with age and use? My truck has about 445,000 miles on it, and this is the first time the AFC cover has ever been taken off and the first time the fuel pin has been touched. There was also a small amount of fuel around the starwheel area, but my friends truck did not have any fuel puddling up in his. Just curious if this means anything or not.
Thanks,
Dawson
Old Sep 10, 2008 | 11:00 PM
89f150's Avatar
My truck has 370 thousand miles and it also had a residue with some fuel in the botton. Im not sure if its good or bad.
Old Sep 11, 2008 | 05:03 PM
Residue is normal, that's what's left of the grease that was put there from the factory. A little fuel is not unusual, but as long as it's not spilling out the AFC vent it's not a big issue.
Old Sep 11, 2008 | 05:10 PM
EatMySmoke's Avatar
Thanks Wannadiesel. What kind of changes in performance will result from rotating the pin?
Dawson
Old Sep 11, 2008 | 05:12 PM
Rotating it so the deep side is forward will give you more power. Don't just go by where it was stock and rotate it a certain amount, they are all over the place. Examine the pin closely, find the deep side, and put it towards the front.
Old Sep 11, 2008 | 05:16 PM
EatMySmoke's Avatar
That is what I did. I marked it first, pulled it out, and then rotated it so the deep side was facing to the front. A friend of mine told me that it might improve mileage some so I was curious if it might. Although if it is sending a lot more fuel then that wouldn't make sense to me.
Thanks,
Dawson
Old Sep 11, 2008 | 05:31 PM
Won't hurt mileage as long as you don't change your driving style, though.
Old Sep 11, 2008 | 10:49 PM
mhuppertz's Avatar
Good luck not changing you driving style though!!!!
Old Sep 11, 2008 | 11:50 PM
NotEnufGarage's Avatar
I'm hot roddin' mine like crazy, but my mileage is still better than before I started moddin' the truck.
Old Sep 12, 2008 | 12:06 PM
EatMySmoke's Avatar
I have a pretty laid back driving style. I may be 20 years old, but all my friends say I drive like a grandpa.
Dawson
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
West Coast
May 26, 2007 10:22 PM
bigragu
Oct 17, 2005 04:07 PM
Crimedog
Mar 11, 2004 01:54 PM
