Fuel line problem
Fuel line problem
Guys while putting my 3200 rpm spring I managed to break a fuel line.
Can I cut the bad section, and splice the ends with a piece of rubber fuel line? Or do I have to replace the WHOLE stainless line?
Thanks, Tony
Can I cut the bad section, and splice the ends with a piece of rubber fuel line? Or do I have to replace the WHOLE stainless line? Thanks, Tony
Which line? If it was any of the 6 from the back of the pump to the injectors you need to replace the entire line.
BTWDYK Each of the 6 injector lines are the exact length and exact c.c. In capacity or the injectors will not work properly.
That is why some of them are wound up like a broken pretzel to take up the excess length.
If it was the low-pressure line then you will be OK with splicing it.
Be sure to use a hose rated for diesel fuel service.
Jim
Jim
Jim
Jim
The line is physically bigger, hence the name. It uses rubber line and push-lok fittings, I believe. If you're serious about the VE power race, some version of the big line setup is a must in order to supply the VE with the volume it craves at higher power levels. For sub 350HP, stock lines will be OK.
I went one step farther and also replaced the line between lift-pump and filter with a second Big-Line Kit plus a fitting to thread into the lift-pump outlet.
With the Big-Line Kit, you also gain a port for tapping in a fuel-pressure gauge-line, and the ability to add as many extra attachments as you desire, by simply cutting and clamping the hose.
Should you later desire to re-locate/replace the fuel-filter, the job is much simplified with rubber hoses.
Etc. Etc.
jentas
Jan 29, 2010 01:34 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
colson22
Sep 27, 2007 08:51 PM
