Fuel Issues Air?
Old Oct 23, 2017 | 09:04 AM
ZAAR's Avatar
Fuel Issues Air?
Hello Friends,
So I am sure this topic has been beaten over and over,
but I am at some ends here before I continually throw parts then scratch my head. So I stepped away and I'm in the process of actually doing something smart Research. lol.
So replaced the lift pump, checked for voltage at the FSS 11 and 10 volts, so there is voltage there, manually primed the lift pump to purge air from the lines and to IP cant get a full flow from the purge bolt to the IP?
I did delete the fuel heater and installed a plug for the filter to fit directly to the surface with a water drain under the unit. now with this new filter in
its tight but before this started it was leaking a bit from the seal where the filter meets the mating surface so I tightened this thing best I could.
still cant stop the air issue... so?
looking to figure out where air may be coming from thinking that the line from the tank to intake on lift pump is pulling air possibly?
what are some other things you all have experienced fail that cause this no start condition?
every and all info appreciated.
Thanks
Zaar
Old Oct 23, 2017 | 04:25 PM
edwinsmith's Avatar
Originally Posted by ZAAR
Hello Friends,
Thanks
Zaar
There are rubber lines going from the tank pickup/gauge sender unit in the top of the fuel tank that goes to the metal line. Assuming the metal line isn't rusted the rubber line may be going bad. Unfortunately you have to drop the tank to replace it. I replaced all the rubber lines at the tank which included the supply line, the return line the vent pipe and the fill pipe, when I had the bed off last year. If you got a hoist or six-eight guys taking the bed off may be easier to replace the rubber lines.
Edwin
Old Oct 23, 2017 | 08:43 PM
bigragu's Avatar
Edwin, did you upgrade the fuel line in size, or stay the same?
Old Oct 23, 2017 | 08:59 PM
edwinsmith's Avatar
Same sizes. Don't ask me what they are. 5/16 I think. I don't need that hi-perf stuff right now. Maybe if we decide to pull a trailer again.
Old Oct 24, 2017 | 08:22 AM
ZAAR's Avatar
Thank you Edwin,
I am going to try to remove the Bed this weekend with a hoist and a makeshift brace.
if that's not possible I will just figure out the best way to drop the tank from under appreciate all the info.
Old Oct 24, 2017 | 08:29 AM
The bed can be pulled safely using an engine hoist and 3 or 4 decent ratchet straps from the corners of all the pockets in the bed.
Lift up in the center where all the strap intersect.
I did that last week on a '95.
Remember the filler neck for the fuel tank and tail light wires before lifting.
Old Oct 24, 2017 | 09:34 AM
maybe368's Avatar
If I read this thread correctly, you don't really know where the air leak is, right? Is so, I would put a few pounds of air pressure into the fuel tank to see where the leak is coming from, If you already know where it is, then, in the words of Gilda Radner, nevermind...Mark
Old Oct 24, 2017 | 09:38 AM
ZAAR's Avatar
I'm on the part where I'm going to try anything I can.
never had the bed off yet so I am quite curious.
Old Oct 24, 2017 | 09:51 AM
maybe368's Avatar
Just stick an air hose into the tank, stuff some rags around it and give it a few pounds and a few minutes and the leak will appear. That is if it is a visible location, if not, then pull the bed...Mark
Old Oct 24, 2017 | 09:54 AM
ZAAR's Avatar
lol hook a hose up to a cheetah tank and let it go!
now that would need a video for Fail of the year.
I will surely try pressure in the tank to see if I can locate the leak. thanks mark
Old Oct 26, 2017 | 07:04 AM
nonrev's Avatar
10 Year Member
This is what i made, just used an old fuel cap and drilled it out put the fitting in used 8 lbs regulated and in less than 5 min found my leaks
herb
Jul 18, 2008 08:25 AM
RyeThomas
Jul 26, 2007 10:30 AM
BIGHEAD
Jul 24, 2006 07:49 PM
SolarYellow05
Dec 11, 2005 08:47 PM
therobzilla
Aug 30, 2004 09:16 AM
