flex plate torque
Old Jul 5, 2013 | 04:56 PM
speed75's Avatar
flex plate torque
whats the proper torque for flex plate to crank
Old Jul 5, 2013 | 06:12 PM
patdaly's Avatar
55 Lb/Ft.
BILTIT's Avatar
A quick Internet search brought up 101ftlbs.
Old Jul 5, 2013 | 08:42 PM
BigIron70's Avatar
Cummins Guru
Tighten the bolts in a criss-cross pattern to 137 N·m (101 ft. lbs.) torque.
Old Jul 5, 2013 | 08:48 PM
speed75's Avatar
55 or 101 flywheel says 101 is flex the same
Old Jul 5, 2013 | 10:35 PM
j_martin's Avatar
FP to TQ 55
FP to crank 101
Old Jul 6, 2013 | 07:37 PM
patdaly's Avatar
Um, is the FSM wrong, or does the first gen use different values?
On edit, my 91 FSM says the same thing.
I did catch the 101 Lb/Ft. but was mentioned as a flywheel, so I surmise that is for manual equipped trucks.
Old Jul 6, 2013 | 10:46 PM
j_martin's Avatar
Well, when I assume common sense things, I get my foot stuck in my mouth.
It seems that though the bolts go into the same holes in the crank as flywheel bolts, they are to be torqued to 55 ft lbs.
Plate to TQ seems to vary from twenty some to 55, with the diesel being on the low end of the list.
This is from the 93 fsm, as opposed to a second gen book. Tranny would be a 46RH
Old Jul 7, 2013 | 12:13 PM
speed75's Avatar
thanks guys
Old Jul 7, 2013 | 01:02 PM
patdaly's Avatar
JMartin, I am also slightly confused as to why you would torque the flywheel bolts differently than the flex plate, the only thing I could think of is perhaps the flexplate to crank bolts have a thinner head? Traditionally your torque values are determined by the size of thread and grade of bolt, which would be the same for both conditions.
Old Jul 7, 2013 | 02:09 PM
j_martin's Avatar
If they do, that would be the difference.
I was raised with "The correct torque is just before it twists off."
herb
Feb 11, 2011 10:06 AM
bhoff1175
Dec 17, 2006 12:02 PM
whazzup
Aug 24, 2003 08:21 AM
CR7135
Jul 14, 2003 10:19 PM
