motor temp?
Old Jul 5, 2013 | 11:28 PM
willy wagon's Avatar
motor temp?
93 3/4 ton with auto. have done some upgrades, big exhaust and intake, pump turned up etc. seems to run easily to 200 to 210 with just a 25 ft fifth trailer in very small hills. i think this is a little high. i know the rad is good had it redone. any ideas?
Old Jul 5, 2013 | 11:47 PM
ClassA4x4's Avatar
Imo, 210 towing a loaded 25ft trailer over small hills is not high at all, even with OD off.
Old Jul 6, 2013 | 09:18 AM
sooty's Avatar
is your fan clutch locking up where you can hear it?
Old Jul 6, 2013 | 09:28 AM
Bob Beauchaine's Avatar
A good freind had the same problem. He is towing a mobile slaughter trailer that weighs just over 5000 lbs empty and about 6500 lbs loaded. We attacked the problem piece meal - thermostat - radiator cap - coolant level etc. He tows quite a few back country roads with some steep grades and roller coaster ups and downs. Since I run a Horton electronic fan and my old OEM fan was still good we swaped my OEM fan to his '93 - end of problem.
Bob
Old Jul 6, 2013 | 04:18 PM
NE frmhnd's Avatar
To get it much cooler I think you'll need a 5 speed or 47RH swap. The engine coolant pulls most of the heat out of the transmission fluid.
If your water isn't too hard you could rig a spray bar for when it gets warm.
These only came with what, a 180 degree t-stat?
Old Jul 7, 2013 | 10:26 PM
thanks for the replys. ya i would like to put the tranny cooling somewhere else. i have an auxilary one under the bumper but it is still running through the original cooler.
Rednecktastic
Dec 18, 2009 08:58 PM
ryan10
Aug 10, 2007 09:38 PM
Common
May 9, 2007 12:11 AM
coupdetat
Feb 17, 2007 12:52 AM
