View Poll Results: ? change front tranny seal when changing torque converter (230,000 miles on truck)
yes
90.91%
no
9.09%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Flex plate/Torque converter
Old Jan 12, 2011 | 01:22 PM
herb's Avatar
Ok sent flexplate and triple loc ATS torque converter to repair facility in Mo to install in truck after truck broke down week before Christmas -----
Am now having a transmission fluid leak from inspection plate--assuming it is the front input shaft seal-----The truck has 230,000 miles on it-----
How many people would have put this seal in while they had tranny pulled ? I suggested it to the repair facility but they failed to do it.
Old Jan 12, 2011 | 01:41 PM
cbrahs's Avatar
you will already be there. cheap insurance to do so. if for instance the seal is already weak but not leaking, remove and install the converter and that in itself pushes it over the edge then starts leaking then you will be doing it all over again.
Old Jan 12, 2011 | 05:26 PM
Sur5er's Avatar
With 230K on the same front seal, you can bet that the seal and front pump cover have "worked things out". When you changed to a new TC, the wear surface was different. I wouldn't worry about it, just have them drop the tranny and do it right! It didn't leak when you brought it there did it?
Old Jan 12, 2011 | 06:08 PM
herb's Avatar
Nope has never leaked a drop---problem is had it done in Mo and truck is back in Michigan and needing to take another load to New England next week
Old Jan 12, 2011 | 06:22 PM
herb's Avatar
I did call the repair facility in Mo this morning who did the work and ask if they had changed the front seal --- Marshfeild Towing in Marshfeild Mo.----Spoke to owner and he said the paperwork was at another location --said he would check it out and call me back.
haven't heard back from him yet.
Tranny is dropped and seal is leaking.
Old Jan 13, 2011 | 10:51 PM
quadman20's Avatar
Heck my place did that regardless and I'm at 65k
Old Feb 11, 2011 | 10:06 AM
herb's Avatar
Well, ended up they did not change the front seal as they were asked to do---tried to get them to pay to get it redone ---of course their response was NO !
speed75
Jul 7, 2013 02:09 PM
cowboykilla235
Oct 29, 2012 08:33 PM
THEMIDAS1
Jul 1, 2010 08:42 PM
bhoff1175
Dec 17, 2006 12:02 PM
