first gen parts compatibility? 91 to 93
Old Dec 28, 2013 | 10:24 PM
Mr. Janes's Avatar
has anybody made a list of what parts are transferable from the early non-intercooled trucks to the later (1993) intercooled trucks? I'm parting out a '91 but don't want to get rid of anything i can use. both are 250s/4x4s /auto.
Old Dec 28, 2013 | 10:48 PM
I'd save pretty much everything I had room for. Short of the wiring....the trucks are pretty much all interchangeable. The stuff that isn't interchangeable is usually in demand by someone.
Old Dec 28, 2013 | 11:06 PM
Mr. Janes's Avatar
i guess i'm wondering more specifically what isn't interchangeable. a few things i know: injectors, IP (without modifications), intercooler components.......
Old Dec 28, 2013 | 11:39 PM
simplysmn's Avatar
81to 93 is all same body style so fender's and stuff like that swap over real easy As far as injection pump it will work but has to be changed around some .
Old Dec 29, 2013 | 02:43 AM
209trucker's Avatar
Injectors are interchangeable with an adapter
Old Dec 29, 2013 | 06:45 AM
carl48's Avatar
save the wiring, I had saved the wiring on a rolled 93 and was very helpful finding a electrical problem on a 91. gauges did not work and blew fuse, it was easy to follow the blue wire with white tracer along the harness to a splice to 6 other b/w wires in the loom totally undetectable to the eye then trace each out and start disconnecting one at a time to find it. save everything, if you have a turn signal or key problem simply hold the piece up to the steering column and connect it up and see if it fixed the problem
Old Dec 29, 2013 | 10:39 AM
Mr. Janes's Avatar
can you tell me more about that? (the injector adaptation). Thats actually what i'm working on right now.
Old Dec 29, 2013 | 12:16 PM
209trucker's Avatar
With the adapters you can make the 7mm intercooled injectors fit in the non-IC 9mm trucks. A lot of diesel performance sites have them, even eBay.
Old Dec 29, 2013 | 01:41 PM
He is parting a '91 and wants to keep parts for a '93.
Getting those 9MM injectors in a 7 MM hole will be tough.
Old Dec 29, 2013 | 02:02 PM
Mr. Janes's Avatar
i thought maybe he had some sort of magic process that i was otherwise unaware of up to this point!
Old Dec 29, 2013 | 02:28 PM
I am all ears too.
Old Dec 29, 2013 | 04:43 PM
209trucker's Avatar
Haha, yeah sorry probably should have paid more attention. I don't know of a way to make 9mm's fit in a 91.5+ truck.......
Yet
Old Dec 29, 2013 | 06:08 PM
maybe368's Avatar
Yet
There is 1 way, a drill, a tap, a very good magnet and the world's largest juevos...Mark
Old Dec 29, 2013 | 06:10 PM
209trucker's Avatar
Hahaha. I thought about mentioning that, you would need some serious confidence for that job.
Old Dec 29, 2013 | 07:13 PM
Ikes91's Avatar
The other way is to have the injector tip machined down to 7mm, I've seen it somewhere....just can't remember
nbaggett89
Dec 26, 2015 09:36 AM
MikeThomas
Feb 12, 2007 05:51 PM
kawi600
Mar 16, 2006 12:25 PM
CTD_Neil
Jul 19, 2005 08:13 PM
TGCTD
Jun 6, 2004 12:42 AM
