Extra Stinky
Old Oct 28, 2006 | 05:24 PM
mhuppertz's Avatar
Extra Stinky
Now that I am pushing more boost I noticed my engine stinks more than it used too. I was afraid I might have popped a head gasket but the oil looks fine (no water). Any ideas?
Old Oct 28, 2006 | 05:45 PM
Totallyrad's Avatar
Making more heat???
Old Oct 28, 2006 | 06:06 PM
W900A's Avatar
The more boost you put in the more engine pressure you create as some compression gases will escape the rings and try and pressurize the crankcase. At high load there is probably a significant increase in visible "smoke" from the engine breather tube. It's nothing to worry about as long as the engine breather doesn't get plugged up.
Old Oct 30, 2006 | 06:46 AM
flashgordon's Avatar
How much boost are you pushing?
Old Oct 30, 2006 | 03:41 PM
mhuppertz's Avatar
I found the problem, and I am extra stupid!
I had forgotten to pull one of the radiator blockers out before I headed up the hill!
Old Oct 30, 2006 | 04:07 PM
Totallyrad's Avatar
Would that be the same as an custom designed adjustable pasteboard winter front?
Old Oct 30, 2006 | 04:12 PM
mhuppertz's Avatar
It's even more redneck than that. I use two paper sacks folded flat, one on each side of the radiator....
Old Oct 30, 2006 | 04:32 PM
Totallyrad's Avatar
Oh, you have the one from J. C. Whitney. I hope you didn't pay more than $64.95.
BC847
May 11, 2007 07:36 PM
DeanM
Mar 12, 2007 06:58 PM
betsycam
27
Jul 23, 2004 09:12 PM
gofastman
Apr 8, 2003 08:38 PM
