Altenator Tach.
Altenator Tach.
Is there a way to calibrate the altenator tach? seems like it won't go over 2200 rpm when I first got it it went close to 3000 rpm or is there something wrong with the tach or pickup on the altenator?
a couple ways to calibrate it...
one...use an optical tach to measure what the engine is actually turning...
two...use a calculator to figure out what the RPM's "should" be at a given speed based on your tire size, transmission, and differential gearing...
maybe some other ways...but those both work...
Greg
Greg
When I got mine, (Autometer) it had a calibration adjustment on the back of it. I calibrated it by letting the motor warm up very nicely and had someone mat the fuel to the floor while I checked to see that I was getting full throttle. I adjusted the tach to read about 2,700 Rpm. At idle, it sat at 750-800 Rpm. Good enough for me!
Wheelo
Wheelo
Carl,u need to put some reflective tape on your crank pulley,grab a laser tach,a buddy,start at idle,calibrate your tach to the laser tach.then go full throttle,then calibrate again.both will read the same when done...
but my AutoMeter had an allen screw on the back, which allowed you to remove the cover of the gauge...
the adjustment was actually a VERY small flat head screw on the back of the gauge (once the cover was pulled off)...it's recessed down into the gauge...
Greg
Ricks 2500 CTD
11-28-2007 08:36 PM
