Engine running rough after swap
Old Aug 4, 2014 | 02:28 PM
Nonicpower's Avatar
So my 90 recently had a case bolt fall out and kill the engine. I bought a 91.5 engine and made 2 out of 1.
Its all running now but not running right. #1 and #4 injectors are failing the cut out test, it smokes like a train, doesnt spool very good and sputters when I rev it.
Any thoughts? Could it be a pump issue or are the injectors stuck shut?
Old Aug 4, 2014 | 02:44 PM
bannerd's Avatar
I would check the injectors.. could also very well be a timing issue.
Old Aug 4, 2014 | 02:50 PM
Nonicpower's Avatar
The injectors that came with the engine had two stuck open, I bought a used set and that fixed that but now I think they are stuck closed.
I dont think it is timing, my marks are lined up on the gears.
I have the pump pulled to the head
Old Aug 4, 2014 | 03:41 PM
Angry Johnny's Avatar
If it's just two cylinders it isn't a timing issue. Are the two dead holes the same ones that had the stuck open injectors? Try using two from the other set that weren't stuck open.
Diesel is as simple as it gets, air, fuel and compression. You might want to recheck your valve adjustment also, might have a tight valve or one that's really loose not letting air in or out.
Old Aug 4, 2014 | 06:01 PM
Nonicpower's Avatar
Yes the dead ones are the same ones that were stuck open.
I tried a couple different injectors from the second set but it didnt change.
There is fuel at the injector, how likely is it that the pump is not making enough pressure to pop the injector?
Old Aug 5, 2014 | 05:58 AM
That's possible, crack a line on a good cylinder and crank it over, see how it squirts out then crack a line on the dead cylinder and see how it squirts out. I'm sure you know better than to hold your hand around it or get to close right?
Have you rechecked the valve adjustment? Also roll it over with the valve cover off and make sure the valves are opening and closing properly.
Old Aug 7, 2014 | 06:24 AM
Jim Lane's Avatar
Maybe there is trash in a few delivery valves.
Are you sure the injectors got plumbed correctly?
Old Aug 7, 2014 | 08:27 AM
Nonicpower's Avatar
Im sure the 4,5,6 are b/c the clamps didnt come off the lines.
The front 3 Im not sure but I cant get a clamp back on em. I put an non IC pump on an IC engine with IC lines and the lines dont fit too well
Old Aug 7, 2014 | 09:25 AM
j_martin's Avatar
Originally Posted by nonicpower
im sure the 4,5,6 are b/c the clamps didnt come off the lines.
The front 3 im not sure but i cant get a clamp back on em. I put an non ic pump on an ic engine with ic lines and the lines dont fit too well
bingo!!!
Old Aug 7, 2014 | 06:26 PM
Nonicpower's Avatar
What is bingo j_martin?
Old Aug 7, 2014 | 09:26 PM
j_martin's Avatar
#1 and #4 injector lines are interchanged.
I am assuming that you have verified that #1 and #4 have compression.
Old Aug 10, 2014 | 07:44 PM
Nonicpower's Avatar
They were not interchanged. I did not take the clamps off of 4,5,6.
It turned out to be an injection pump issue. Put my other pump on and it runs fine. Got to look at the other pump now.
Thanks for the input boys
builtnotbought1
Jul 6, 2014 09:49 PM
jjrightmire1973
Nov 17, 2008 07:50 PM
francis212
Dec 5, 2006 03:39 PM
Fishbait
Dec 3, 2006 07:55 PM
Hummin Cummins
Oct 29, 2003 07:19 PM
