Rough Idle after running hard
Old Nov 24, 2006 | 03:08 PM
francis212's Avatar
Everytime i run my truck hard i get a real lopey idle for a couple minutes then it slowly goes back to normal. It is a HRVP is this normal, i have heard of rough idleing HRVP trucks but never hear of it rough idle after hammering down. Ther no codes and power seems to be there jsut wanted to make sure somethign not wrong.
Old Nov 25, 2006 | 09:46 AM
Sea Bass's Avatar
Mine does the exact same thing. It idles a little choppy after gettin' on it hard. But, I don't have a hrvp. It's only done it since I installed the my injectors so I just always figured it was that.
When did yours start? When you installed your pump?
Old Nov 25, 2006 | 11:58 AM
francis212's Avatar
Yea i remember one time with my mach 4s and the stock Vp i got on it hard and let off and the truck shut off, i heard of that happening to someone before i just never heard of idle being rough after getting on it hard i talked to a guy last night said it is normal for that to happen. we'll see i guess. maybe we're sucking air somehow i dunno i mean it really doesnt bother me that much as long as nothing is wrong. good luck with it
Old Dec 3, 2006 | 05:56 PM
JIT's Avatar
JIT
Mine does it too when I run it hard. I've just chalked it up to common occurance when I run her hard. It smooths out when I rev the engine a bit. No biggie for me!
Old Dec 5, 2006 | 03:39 PM
finally got one's Avatar
been there
my stock started idling funny, no big deal to start. after about a month got a little worse, finnaly got so the truck would hardly stay running. FUEL PRESSURE VALVE went bad. temp quick fix surgical clamp on return line helps untill i can afford $440 replacement
toupee
Dec 29, 2007 10:08 AM
what
Nov 13, 2007 11:06 AM
J Banning
27
Sep 12, 2007 11:22 PM
wilderness
24
Feb 18, 2007 11:41 PM
Ilikebikes
Nov 29, 2006 06:07 AM
