Help!...Running rough(er) after vp44 replacement today!
Old Dec 2, 2006 | 09:28 PM
Fishbait's Avatar
Unhappy Help!...Running rough(er) after vp44 replacement today!
I just finished installing my "new" IP a hour ago and after bleeding the lines it started right up and ran rough for 30seconds and then idled nice and smooth........after letting it run for 10 minutes I went to take it down the road and it ran nice for 2 minutes and started to run rough at idle as though it was missing, at hi speeds it seems ok, bu stters a bit getting there. It has an acrid eye burning exhaust smell if you sit and juice it some. I checked and checked for leaks even cleaned it up with degreaser and have not found any evident fuel leaks.
I am at wits end on this........What happens if for some reason the key fell off the shaft on the install...how will the truck run...I hope that is not the case but I am grasping here any ideas guys..?
Old Dec 3, 2006 | 07:50 PM
RickCJ's Avatar
If the key fell off I don't think it would run. Did you old pump have an electronic or mechanical failure? If mechanical maybe you have some metal shavings in an injector or line?!
Old Dec 3, 2006 | 07:55 PM
scottsjeeprolet's Avatar
I don't see any guages listed in your signature, did you replace the LP as well. This should always be done when replacing the VP44. What's the fuel pressure?
Nonicpower
Aug 10, 2014 07:44 PM
Jasper
15
Jan 19, 2010 09:35 PM
jjrightmire1973
Nov 17, 2008 07:50 PM
francis212
Dec 5, 2006 03:39 PM
Mexstan
Mar 31, 2003 02:37 PM
