D250 Dana 70 wheel seal leak and bearings.
Old Apr 29, 2018 | 08:16 PM
  #76
maybe368's Avatar
The star wheel adjusters are the same. I am not really sure what the problem is, but there is something wrong and you will probably need to remove the drums to see what it is...Mark
Old Apr 30, 2018 | 08:30 AM
  #77
j_martin's Avatar
Originally Posted by Grant31781
If you look at the picture on page 3, the wheel cylinder pushes both shoes out. The adjuster cable is anchored to the parking brake lever piviot bolt. When the wheel cylinder pushes out the shoe, it tightens the cable pulling on the spring connected to the adjuster arm. To me it looks like any braking action will pull on the adjuster.
If the adjuster is on the wrong side, it will back off the adjustment every time the brakes are applied, not over tighten it.
I can think of two things that can cause an auto adjuster to over tighten.
1. Brake drum out of round. The shoe and adjuster can make a click as it follows the "square" drum.
2. Possibly an oversized drum and shoes that don't match the radius. The shoe would have to flex for it to move the adjuster.
Either way, it's time for a new drum.
Old Apr 30, 2018 | 09:11 AM
  #78
Grant31781's Avatar
Dang this is a brand new drum from Napa. Is it possible that they will wear in over time? I may just disconnect the auto adjustment cable and manually adjust them.
Old Apr 30, 2018 | 10:13 AM
  #79
maybe368's Avatar
Take them to a good brake or machine shop and have them turned to a true round condition. Certainly even the cheap Chinese drums have enough meat to true them up...Mark
Old Apr 30, 2018 | 08:58 PM
  #80
j_martin's Avatar
Do the shoes lay true in the drum? Yer looking for radius error in the shoe.
loudhornsrule
Jul 24, 2016 03:54 PM
Diesel Jeff
Oct 16, 2008 07:29 PM
billmac
Feb 12, 2006 09:49 PM
jeff_hiller
Oct 22, 2005 09:47 PM
SSV1761982
Jun 24, 2004 11:15 AM
