D250 Dana 70 wheel seal leak and bearings.
Old Apr 14, 2018 | 01:02 PM
  #46
bigragu's Avatar
Originally Posted by kensmachine
I have not found a left side parking brake cable that is right for the 2WD trucks thay are all too long. what happens is you have a big loop in the cable and the cable wont work smooth and the brakes drag I have tried Dodge, NAPA, Raybestos, and others last time I sent a new out and had it shortened. still need to get it put in. all the books only list one cable for the 2WD or 4WD trucks. also make sure the vent fitting that screws into the axle housing is clear if not clear the prussue in the housing builds up as the gear lube heats up and the seals can leak Ken
Ken, try and find that post of mine that Grant found that lists those raybestos brake cables. The reason being is that I know I wrote down the lengths of the three brake cables next to their respective part numbers. I’m curious as to what length you had for that drivers side cable. It should be the same as the 4x4, unless I’m missing something. The only differences in lengths will be at the front cable, from the cab to where it unites with the two rear cables, due to single cab vs. extra cab.
Old Apr 20, 2018 | 06:07 PM
  #47
Grant31781's Avatar
Does the spring side of the seal face the inside of the hub or outside?
Old Apr 20, 2018 | 06:36 PM
  #48
edwinsmith's Avatar
The inside where the lubricant is.
Old Apr 20, 2018 | 06:40 PM
  #49
With the real installed, you should not be able to see the spring as it should be facing inside the hub where the gear oil Will be.
Be very careful installing that seal. You should be using a seal installation tool, or a socket big enough to match the diameter of the seal. You should never be tapping on the seal directly with a hammer. It damaged / distorts the seal seal, and at $20 a piece,it gets expensive.
  #50
Grant31781's Avatar
Thank you.
Old Apr 20, 2018 | 06:58 PM
  #51
Grant31781's Avatar
I was typing at the same time you posted. I use a block of wood usually to drive them in.
Also Napa has this degreaser called black max. It works really well. It has caustic soda in it.
Old Apr 21, 2018 | 07:53 PM
  #52
Grant31781's Avatar
The parking brake cable for the driver side was correct and had all the clips needed. Raybestos bc93587.
The Carlson h2316 drum brake hardware kit came with two sets of adjusters and the arms. Both sets are for the right side. You would think the kit would be for both sides.
Good thing the arm and adjuster was in good shape.
I have some dragging of the shoes in one spot as I turn the wheel. Not sure why it's doing that. I guess the drums are out of round a little.
I still have to do the other side
Old Apr 21, 2018 | 08:00 PM
  #53
maybe368's Avatar
Good think the arm and adjuster was in good shape.
You got the adjusters from rockauto, right? They are real good for returns. I would call them. They have sent me new parts and not required the return of the old in the past...Mark
Old Apr 21, 2018 | 09:34 PM
  #54
Grant31781's Avatar
I did, but now I don't need the other parts since I got the left back together.
Old Apr 21, 2018 | 10:23 PM
  #55
I've experienced the same thing. Sligtly out of round drums.
I try to minimize this by adjusting till it barely touches while spinning the drum. I then start the truck and cycle the brake pedal a few times. This "centers" the shoes.shut the truck off. I readjust till I get the drum barely touching again, star the truck, cycling the pedal again.
Once I feel comfortable the drums and shoes are as close together, and centered as best as possible, I use a bent pic, push the adjuster level outwards, and loosen the adjuster to where the shoe no longer touches the drum.
After driving for a couple weeks I readjust all over again.
Imo, leaving shoes to drag warps drums, and damages shoes.
Btw. In order for the brakes to " self adjust ", you need to use the parking brake each time you park.
Just my way of doing things.
Old Apr 23, 2018 | 05:52 PM
  #56
j_martin's Avatar
I disagree T man. The parking brake lever and the cylinder perform the same action on the shoes, and the adjusting cable is tightened (lifted) by the motion of one of he shoes. When the motion gets long enough, it clicks the star wheel one click.
Old Apr 23, 2018 | 06:56 PM
  #57
Next time I have the rear brakes apart, ill test the theory
Old Apr 23, 2018 | 07:01 PM
  #58
Grant31781's Avatar
The rear brake shoes pulls the cable on the adjuster. The wheel cylinder does work the adjuster.
Old Apr 23, 2018 | 07:02 PM
  #59
maybe368's Avatar
I agree with Mr. Martin. One way to adjust the brakes is to backup and brake hard a few times. The 76 and 77 El Dorado calipers that I used on the disk conversion are adjusted by the use of the parking brake. The parking brake is a ratcheting setup and will not close as the pads wear,like most types of disk brakes, without using the P-brake...Mark
Old Apr 23, 2018 | 07:08 PM
  #60
Well, its 3 against one so odd man out.
Lol
