Cummins Engine #??
Old Jul 27, 2006 | 06:18 PM
whereswaldo250's Avatar
Question Cummins Engine #??
Hey guys
I called Cummins to see how much a lift pump would be and it turns out that I need to give them my engine number. I looked in the manuel and I can't seem to read the emblem so does anybody know what the engine code/# would be on a 92??
Thanks
Old Jul 27, 2006 | 06:21 PM
44815853
You can get an aftermarket stock type replacement pump from usdieselparts.com for under $40 shipped. It's made by Delphi, I had one for a while before I upgraded to the piston pump.
Old Jul 27, 2006 | 06:26 PM
would that be better then the one from cummins?
Old Jul 27, 2006 | 06:34 PM
I found it, when you had it on your truck did it seem to work alright? I'm a person who likes putting on parts from the company who made the vehical but for 40 bucks ill look into it better then 120.
Thanks Dave
Old Jul 27, 2006 | 06:38 PM
It worked fine, much better than the leaky old one. Made 7 psi at idle when I took it off.
Old Jul 27, 2006 | 06:57 PM
csramsey640's Avatar
I took Wanna's advise and purchased one. Great psi #'s, fast service, and a good pump. Chances are Delphi makes the Cummins LP anyway. Since Delphi does have thier hands in some of Cummins injector lines.
Old Jul 27, 2006 | 07:26 PM
The Cummins pumps are made by Carter.
Old Jul 28, 2006 | 04:17 PM
Hey Dave
today I got my lift pump from NAPA and there parts are made buy carter, and 6-7 psi. My truck seems to feel better, it was only 88 bucks with tax
Thanx for the help
Old Aug 1, 2006 | 12:38 AM
xjjones's Avatar
Engine Id Help
Can someone please tell me or show me with a pic. Where the Cummings engine number is on a 1st gen. I have looked and given Cummings ever number i can find. What am i missing?
Old Aug 1, 2006 | 12:56 AM
bgilbert's Avatar
Cummings? You must mean Cummins. There is an ID tag on the timing cover, right in front of the injection pump. You want the 'serial number'. If your ID tag is missing, you'll need to use someone elses number if you want to order parts from Cummins without part numbers.
andyboland
21
Jan 8, 2020 11:32 PM
mullishacrew
Feb 25, 2011 08:07 PM
12PACK
May 2, 2005 07:13 AM
ChrisLib
Dec 28, 2004 08:51 AM
ProjectM880
Dec 1, 2004 06:40 PM
