A clean Cummins is a HAPPY Cummins
Did a real thorough underhood clean up today in anticipation of the coming BOMB`ing this week. Had to cleanse 170k of builtup crud and grime, after i did it I took her out to get everything dried off, darned WIF lamp came on for about 10 min....whats with that? I`ve seen a couple of old posts about that, either way it went off by itself . The funny thing is I SWEAR it ran better, I figure the old gal must be happy, if she only knew whats in store
Funny thing I noticed the same thing about my truck, it always seems to run better after it has been cleaned
darned WIF lamp came on for about 10 min....whats with that?[
You probably got some water on the sensor at the bottom of the fuel filter.
Originally posted by Geico266
I pressure wash my engine at least 6 times a year. I always try to keep the grime off by spraying the engine down with Simple Green first. So far I havn't hurt anything.
I wash mine down after every oil change. When we built the house, we had a garden hose faucet tapped into the hot water heater. Set the heater at about 160F and it cleans the road crud right off.....
It's alot easier to spot a problem developing if you can notice a leak or such ASAP, and clean engines DO seem to run better....
Derek Edgar
Apr 10, 2013 09:54 AM
converteddzlr
20
Nov 29, 2002 09:48 AM
