broken injector line
Old Dec 9, 2008 | 05:22 PM
jsadler's Avatar
I just found a broken injector line on my 92 dodge. I hope I did not hurt the engine at all. I may have drove about thirty miles like that before I found a problem (hearing impaired so I didn't notice the difference). Are there any after markets out there or will I have to go to dodge directly.
Old Dec 9, 2008 | 05:23 PM
Get it from Cummins. That's where Dodge will get it from anyway...
Didn't hurt anything except your fuel budget.
Old Dec 9, 2008 | 05:57 PM
SmokemS's Avatar
cummins will have it i had mine shipped to me the next day cost me 92 bucks and some change and its real easy to install
Old Dec 9, 2008 | 06:01 PM
Ace's Avatar
Ace
Just curious - how in the heck does an injector line get broken?
Old Dec 9, 2008 | 06:34 PM
jsadler's Avatar
Glad to hear that it didn't hurt my engine. I have been trying to find the part on the cummins site but I guess I will have to call in person. I can not find an actual parts listing on line.
Old Dec 9, 2008 | 08:31 PM
77machomopar's Avatar
When one of mine broke. It just split open next to the nut on the injector side of the line. It split open for about 1 inch. and it was a good size split.
Old Dec 9, 2008 | 09:07 PM
bullfrog5.9's Avatar
it can split from not having those little claps on to they keep the lines from vibrateing to much
Old Dec 10, 2008 | 12:29 AM
jsadler's Avatar
Mine was weakened when someone I called gave me the wrong timing order after I had replaced the injector pump and had problems getting any power. I had to put torque on it to get it to fit. knew it wasn't right so I took it to the mechanic. found out that when I first put the injector pump on I did everything right and had had the timing correct originally. The injector pump was bad and that was why I had problems. So I had the pump rebuilt and reattached. Solved my problems but I figured the line would go sooner or later.
Old Dec 10, 2008 | 04:09 PM
That, or it got bent too far by a careless mechanic and failed there. You can flex them, but you better not bend 'em.
Tasso
Aug 20, 2010 11:08 AM
NoSparkplugs
Apr 30, 2008 11:27 PM
Rpainter
21
Mar 8, 2008 02:36 PM
jon96ctd
May 11, 2007 08:34 AM
robert chilton
Sep 13, 2005 04:50 PM
