broken injector return line
Old Aug 19, 2010 | 09:31 PM
Tasso's Avatar
Hey everyone,
First I'll say hello as the proud new owner of a 95 4wd 3/4 ton 5spd. For what I paid for it I basically stole it, and unfortunately, I got what I paid for. I've been picking up the loose ends, but I've run into a problem that i can't fix.
My injector return line is broken just behind the #3 injector. I've done some searching and I have no idea where on earth to find a replacement... Any ideas?
Old Aug 20, 2010 | 07:20 AM
d-rod's Avatar
the quickest place would be the dealer, or local diesel shop could set you up. or call cummins direct if there in your area. stop in at a good junk yard, good luck!
Old Aug 20, 2010 | 08:01 AM
patdaly's Avatar
Also, Ebay usually has some. Brand new from Cummins might also not be bad. They used the 5.9 on Tractors also, I believe IH, so if you are in farm country.........
Old Aug 20, 2010 | 09:56 AM
infidel's Avatar
The dealer will sell you an updated line just because your problem is fairly common.
What I've done a few times for people who don't want to spend the money is remove the steel line then install a banjo bolt by barbed hose fitting on the injection pump then run hose instead. Removing the steel line isn't easy, I've been tempted to use a sawzall.
Best to run the hose all the way to the tank to avoid future problems.
Old Aug 20, 2010 | 11:08 AM
Tasso's Avatar
My local Denver Cummins dealer shows it in stock and it's not even expensive! This is why I bought a Cummins...
And for future reference: Part number 3926103
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
leftturn7m
Aug 15, 2008 08:20 AM
NoSparkplugs
Apr 30, 2008 11:27 PM
Tiara3100
Jan 14, 2008 10:06 AM
