boost question
Old Oct 9, 2007 | 04:15 PM
ryan10's Avatar
boost question
Hey guys, with the mods in my sig, i am seeing about 26 pounds of boost. does this sound right? is there any way to tell where the wastegate is set? i wouldnt think it would be set at 26. also, i have the stock turbo. does this sound right for it?
Old Oct 9, 2007 | 04:19 PM
It might be set at 26 psi. Those injectors can flow enough fuel to make well over that, but your pump settings might be conservative.
You can test the wastegate with an air compressor (be careful, the actuator won't appreciate 100 psi), or you can try adjusting it to see if you can make more boost.
Old Oct 9, 2007 | 04:23 PM
ryan10's Avatar
Ok, thanks. how do i adjust the wastegate?
Old Oct 9, 2007 | 05:08 PM
ryan10's Avatar
Ok, well it was the wastegate. i turned the rod in a few screws and im at about 30 pounds of boost now. Im on the stock turbo, so im gonna leave it there for now. is this safe? Also, when i get the GDS stage 3 kit, what can i safely run?
thanks.
Old Oct 9, 2007 | 05:33 PM
30 is plenty out of the stock turbo.
Let the EGT be your guide. Start at 30 and go up. If EGT gets cooler, keep going. When it stops cooling down, you have enough boost. Don't run it over 40 psi, though.
Old Oct 9, 2007 | 07:20 PM
ryan10's Avatar
OK, so should i stop at 30 pounds, with the stock turbo, or can i go up on that?
thanks.
Old Oct 9, 2007 | 07:51 PM
DodgerDoob's Avatar
Same deal here. Kind of. My 35 is only making 23 lbs of boost. My stock turbo made more. so I just turn the actuator rod? tighten or loosen? Thanks
Old Oct 9, 2007 | 08:05 PM
ryan10's Avatar
i tightened the rod, about 2 turns gained me 4 pounds of boost, so im guessing its about 2 pounds a turn.
hope this helps.
goose2w1
Jul 23, 2008 10:49 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
