Boost Guage
Old Dec 30, 2004 | 11:16 AM
FIREDUDE's Avatar
Boost Guage
I should be getting my boost guage here in a day or two and was wondering where ya guys hooks ya up at, i am totally clueless at this part
Old Dec 30, 2004 | 11:40 AM
12valve@heart's Avatar
I just removed a screw-in plug (1/8" pipe I believe) on the side of my intake manifold right below where the air intake connects to the manifold and screwed it in there. Anywhere post-turbo will work but I prefer the intake manifold so that I can see what boost the engine is seeing. Just remember to ziptie the nylon line up out of the way so that it doesn't contact anything sharp or hot.
Good luck
Old Dec 30, 2004 | 12:00 PM
jleonard's Avatar
The other Jay beat me to it...but I put mine there as well. On mine there is a solid support plate that blocks it, so I drilled a large (7/8 I think) hole in the plate so I could use a socket on the plug and fittings and ran the line thru the hole.
Jay
Old Dec 30, 2004 | 12:08 PM
Redleg's Avatar
Mine too, the non- inner cooled has the plate to drill through. I put on a grommet to protect the line too.
Old Dec 30, 2004 | 01:58 PM
Garz's Avatar
I couldn't find the plug they're talking about. DUH, it's behind the support plate. So I just drilled and tapped the boost tube over the engine. Works fine, quick to do. Use some plummers tape where any threads are to eliminate leaks.
Old Dec 30, 2004 | 06:16 PM
dzpoorjr's Avatar
Had an 89 and a 93 now tapped in to the same plug on the intake-but if hard to get to-tap into the intake crossover to the turbo-take it off though first! Just to add my .02 worth.
Old Dec 30, 2004 | 08:05 PM
boiler-rat's Avatar
I took off the air intake tube from the manifold and drilled and tapped a hole on the side closest to the firewall. Four bolts and a hose clamp, all easy to get to.
Old Dec 30, 2004 | 08:35 PM
A picture is worth a thousand words:
Old Dec 31, 2004 | 08:46 AM
Redleg's Avatar
That's the spot. But if he's not inner cooled, there is a support plate in the way you have to drill through. The fuel lines mount to it. Conveniently the largest gap between the lines, lines up with the plug.
bigragu
Jan 24, 2006 11:16 AM
snow104
Apr 17, 2003 03:05 PM
soundfetish
Feb 26, 2003 03:35 PM
99purplecummins
Dec 29, 2002 02:07 PM
99purplecummins
Dec 10, 2002 11:50 PM
