Anyone know the fuel tank capacity?
Old Sep 5, 2005 | 03:23 AM
robox's Avatar
Any of you guys know what the fuel capacity of a first gen is (mine's a '93)?
And anyone know how much diesel you've still got left when the "Low Fuel" light comes on?
Thanks,
CR
Old Sep 5, 2005 | 03:36 AM
ares's Avatar
the tank is 30 gallons and the light comes on at 5 i believe...
Old Sep 5, 2005 | 06:05 AM
blueberry's Avatar
30 gal. If I fill up when the low fuel light comes on it takes 23 gal.
-brian
Old Sep 5, 2005 | 09:57 AM
fishin fever's Avatar
What there's an low fuel light hells bells and here i've been sweating when it drops below the 1/4 mark does ya have to hit the "e" for it to lite?
Old Sep 5, 2005 | 10:19 AM
SmokinFive9 4x4's Avatar
I don't have the stock fuel guage anymore, but if I remember right it comes on about 1/8th of a tank. It's on the Cummins Turbo Diesel cluster with the wait to start light and the ABS lights.
Old Sep 5, 2005 | 10:36 AM
Begle1's Avatar
Well, my fuel light always comes on anywhere from 1/4 tank to 1/8 tank. But it usually flickers depending on how fast I'm going or at what incline I'm parked at...
(I figure that if the fuel light is only accurate to 1/8, then I probably shouldn't go below that...)
Old Sep 5, 2005 | 11:42 AM
bgilbert's Avatar
30 gal tank, low fuel light set to come on at 1/6 tank= 5 gal.
Old Sep 5, 2005 | 12:37 PM
frostie's Avatar
Every truck is different. I have 2 1992s and one takes 24 gallons when the light comes on and one takes 26 gallons, most tanks are 30 gallons as others have said.
Old Sep 5, 2005 | 12:52 PM
robox's Avatar
Thanks, gentlemen. I was thinking it was a 33 gallon tank, like my 2nd gen, but the numbers weren't adding up. 30 makes more sense.
CR
Old Sep 5, 2005 | 01:12 PM
bgilbert's Avatar
I'm just spittin out what the book says. Yes I know each truck is different. They're Dodges . Dodge=Different.
Old Sep 5, 2005 | 06:06 PM
DODGE 92's Avatar
fuel tank
around here i saw 2 sizes as said in manual 80 liters and 100 liters
Old Sep 5, 2005 | 08:58 PM
92DIESEL's Avatar
When I ran out of fuel anf filled up it took 32.3 gal... That's including the 1 gallon I got to get it started again. When my low fuel light comes on I still have 100miles left. I don't truct my gauge
Michael
Old Sep 6, 2005 | 07:48 AM
lovemysan's Avatar
The size is should be stamped on the bottom. Mine is a 30.
Old Aug 18, 2007 | 04:48 PM
geeza09drz's Avatar
Go buy the mileage and then you can't go wrong once you know what your getting for fuel mileage.
Old Aug 18, 2007 | 05:36 PM
Boatnik's Avatar
The only accurite meaning of the low fuel light..................it's on! Mine has a mind of it's own. It comes on and goes off at will. I think it is haunted
jj3500
19
Sep 12, 2006 11:50 AM
ddestruel
Mar 26, 2006 01:54 AM
2002cumTRBODSL
Dec 23, 2005 11:01 PM
edwinsmith
Feb 27, 2005 05:32 PM
