Adjusting Caster Camber?
Old Jun 16, 2018 | 04:25 PM
  #46
1972RedNeck's Avatar
Originally Posted by nonrev
my question is will the king pin fit through the knuckle from the bottom up through the top, in other words can I just take the upper cover off an break the king pin loose and pull it out the top
Yes it will if you can get it loose. Typically end up splitting out the hex and then welding a piece of heavy wall square tube to the kingpin and then use a 36" pipe wrench and 6' cheater pipe to get them out. Good times.
Old Jun 16, 2018 | 07:21 PM
  #47
jtamulonis's Avatar
Quick ?, do you think I could just pull the top cap and remove the kingpin and then install the new one without completely dissembling the entire knuckle
the king pin is 1 3/4" od. and the plastic cup is 2" od. it should slide through there like really easy !!
Old Jun 17, 2018 | 08:14 AM
  #48
nonrev's Avatar
Super Moderator
10 Year Member
Thank you, the job went really easy with a wire brush, scraper and the trusty air gun every thing cleaned up easy. passengers side first, 8' piece of square tubing it broke loose way easier than I thought, pulled it out and there was minimal wear but installed the new one anyway with a new seal and gasket. The drivers side how ever took quite a bit more torque to break loose. there was visible wear and gaulding on this side, cleaned it up and installed the new parts.
The test drive showed a definite improvement in the way it handles going down the road, however I still think I need a little more caster (BTW the moog k992 kit is only for camber, I guess I was having a blonde moment when I ordered it
The total time from start to finish was about 2 hours with plenty of breaks, I have a almost 2 yo GSD that requires you to throw his toys for him when you are outside whether you are busy or not!
That's a dog toy lol
showing some wear
installing new seal, just carefully pushed it in with a screwdriver
pass.side on right
This is Ruger
Old Jun 17, 2018 | 09:31 AM
  #49
mknittle's Avatar
showing some wear
Mine is the same way, I feels like it could use just a little more caster.
Old Jun 17, 2018 | 09:48 AM
  #50
nonrev's Avatar
Super Moderator
10 Year Member
Originally Posted by 1972RedNeck
Update:
So far I have went from a mostly slopped out front axle and rebuilt it into a better than new front axle. Even with all the time and money I have put into it, I really haven't improved the way it drove - until yesterday.
My 4* pinion wedges showed up on the Brown truck so I ran the '93 in the shop and got them put in in a 1/2 hour or so. Took it for a spin and the difference is night and day. It drives SO MUCH better - It wasn't terrible before, but now it actually drives itself down the road like it should (i.e. self steer).
I do have a touch of play coming from my less than 5,000 mile RedHead steering gear that will have to be addressed, but the increased caster did the job.
1972RedNeck, What company did you get them from and did you use 3 wedges? the reason I ask is because every thing I have read says that on the pass. side you need to have two, one under the spring and one on top to keep the bolts from binding. also do you have any pics you could post on the finished install.
Old Jun 17, 2018 | 02:34 PM
  #51
edwinsmith's Avatar
Does the spring windup cause the need for wedges to adjust caster?
Old Jun 17, 2018 | 03:04 PM
  #52
maybe368's Avatar
showing some wear
pass.side on right
This is Ruger
Dude, I thought that you said the pins looked good. Try this site:
https://www.personaleyes.com.au/online-eye-test/ ...Mark
Old Jun 17, 2018 | 03:32 PM
  #53
nonrev's Avatar
Super Moderator
10 Year Member
Mark, No excuse but I really don't remember them looking like that or I would have changed them out as I had the parts sitting tight there.
Edwin, It's not spring wind up that will cause the problem, most of the time it is caused from putting in a lift (which I do not have) and then you use the wedges to change your pinion angle, that also affects your caster. With your truck being a 2 wheel drive it's a whole lot easier to change your settings.
Old Jun 17, 2018 | 03:48 PM
  #54
maybe368's Avatar
Did you check to make sure that your steering box is not moving around when the steering wheel is turned. It may not affect caster, but it does affect the ability of the wheels to recenter themselves. Ask me how I know ...Mark
Old Jun 17, 2018 | 06:08 PM
  #55
u2slow's Avatar
I can't see that being it. That could only really happen in 4wd with the rear driveshaft disconnected. These trucks are under-caster'ed from the factory. Longer shackles tilts the axle just like wedges do... and may be an easier/simpler install.
Sufficient caster and a basic stabilizer will center the steering exceptionally well at highway speed....even with sector shaft slop, cracked steering plate, and pitman arm wobbling on the sector shaft. Ask me how I know....
  #56
Yes, bought two sets of two from Summit Racing - just got the cheapest 2.5" wide steel shims they had.
Old Jul 22, 2018 | 03:14 PM
  #57
nonrev's Avatar
Super Moderator
10 Year Member
Update
Well I finally broke down and installed the caster wedges, I went with 3 degree and all I can say is wow it finally steers as it should!
The only thing I'm not happy about now is I think it gives me a little too much pinion angle. Has anyone ever put like maybe 1/2 inch spacers on the tranny mount to lower it a little, or would that put the lower part of the fan too close to the radiator, or any other gremlins that it might cause?
Old Jul 24, 2018 | 10:07 PM
  #58
u2slow's Avatar
Most likely nothing to worry about with stock leafs.
I have successfully run 3" lift and 5" shackles by grinding/smoothing the stock Saginaw CV... or a stock Spicer (2ndgen) CV works unmodified.
Old Jul 25, 2018 | 05:16 AM
  #59
nonrev's Avatar
Super Moderator
10 Year Member
u2slow, are you talking about just changing the cv or the entire shaft from a 2nd gen?
Thanks, Vern
Old Jul 25, 2018 | 05:25 PM
  #60
u2slow's Avatar
Whole shaft, but either way, the diff end was a Dodge 7290 yoke.
2ndgen shaft is a little longer. Lift and shifting the axle forward a little made room for it.
1985cucv
Feb 22, 2019 10:11 PM
shoffs30
Oct 12, 2005 05:07 PM
Txwelder
Jun 12, 2005 02:33 PM
Txwelder
Jun 9, 2005 11:58 AM
xp8103
Nov 8, 2004 10:59 AM
